0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#1098881 04/22/2015 5:20 PM
I think I heard once that our mechanical temp gauges (wiht the sending unit in the block and copper tubing going up to the gauge) can be damaged or destroyed by a block that over heats. Is this the case ? I may have wiped mine out in the latest issue of overheating. It was new and could have been defective ? My motor did get really hot once or twice
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Mechanical temp gauge is pretty tough. If it leaks, however it is toast. Common fail points are the firewall(chafing). Back of gauge in the cluster(bend and pinch). And crud in the head preventing water contact. Bend fractures and kinks will defeat even a new one. Good to run your fingers the length of the "pipe" from "bulb"(the bit in the head) to the back of the gauge. Should be smooth and not kinked. Look at the joint at the back of the gauge that joint has a sleeve to support the tube/pipe and might be where it is kinked or leaking. I have seen them fail because they are too close or touch the exhaust manifold. Common error if you don't know how they work. I hope that helps some.
Steve H
I've had a mechanical temp guage touch my oil pressure guage tubing. Nice little ether fireball under the dash. Live and learn
