| | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I think I heard once that our mechanical temp gauges (wiht the sending unit in the block and copper tubing going up to the gauge) can be damaged or destroyed by a block that over heats. Is this the case ? I may have wiped mine out in the latest issue of overheating. It was new and could have been defective ? My motor did get really hot once or twice | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Mechanical temp gauge is pretty tough. If it leaks, however it is toast. Common fail points are the firewall(chafing). Back of gauge in the cluster(bend and pinch). And crud in the head preventing water contact. Bend fractures and kinks will defeat even a new one. Good to run your fingers the length of the "pipe" from "bulb"(the bit in the head) to the back of the gauge. Should be smooth and not kinked. Look at the joint at the back of the gauge that joint has a sleeve to support the tube/pipe and might be where it is kinked or leaking. I have seen them fail because they are too close or touch the exhaust manifold. Common error if you don't know how they work. I hope that helps some.
Steve H
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I've had a mechanical temp guage touch my oil pressure guage tubing. Nice little ether fireball under the dash. Live and learn
