| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I bought a column shift 1953 enclosed drive shaft 3 speed trans. Will any parts from this trans swap with my 55.2 3 speed open drive shaft column shift trans? Example: side cover, shift forks, cluster gear etc. Other words is it worth hanging on to, so I have extra parts for my 55.2 trans?
TIA. Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Cluster gear fits 1940-63. Not much else will swap.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You may be able to use parts from the side cover depending on which type you have. There is the ball type and the scissor type. The 2-3 shift fork will interchange the 1-R will not. As Dave states, that's about it. Fred
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I was hoping the 53 4 bolt side cover with one shift arm up an one down would interchange on my 58 3speed overdrive trans that has both arms pointing the same direction, so I could install it in my 55.2 3100 which has the one arm up and one arm down set up.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The low-reverse slider gear and shift fork are wider starting in 1955.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The low-reverse slider gear and shift fork are wider starting in 1955. I was able to overcome that issue but I don't recall how. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can use the later 1-R shift fork in the early side cover providing they are both the same style. Fred
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It seems like that's what I did but it has been so long ago I can't recall for sure. The only 'problem' I have is if I leave my hand on the shifter in first gear, the gear slightly rubs another gear. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Brian,
If that's the transmission you got from me, it's an open drive line model, not a torque tube model. It was out of a 54 3/4 ton.
Chris | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1954 3/4 ton 3 speed transmission is the same as the 1948-54 torque tube type, except Chev adapted a strange bushing, seal, and yoke to the rear to make it work with a open drive shaft.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Chris that would be the tranny I'm talking about. Dave, Fred and Cletus, thank you for your replies.
