5 members (Hotrod Lincoln, fonz8261, baldeagle, walter74, 1 invisible), 97 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#1098782 04/22/2015 2:20 AM
Hey guys,
Here is the bell housing I've got in my truck connecting a '58 235 to a '58 3 speed/OD trans. See photo in link: BELLHOUSING PHOTO
Does this type of bell housing take a cover on the bottom? To protect the bottom of the fly wheel I assume... Mine didn't come with one when I bought the motor and bell housing, but I looked under my friend's Fleetline and he had some sort of cover under his.
Building a '50 Panel 3100
yes it should have a cover.. they had several different types through the years..i am not sure which you need .. if you figure out what type you need and dont have one i have several different types for sale..
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
Two pieces of sheet metal serve as covers in 1954. One vertical piece/cover and one bottom piece/cover. They get installed in that order. The stove-bolt screws for the bottom piece can be reached with a screw driver that goes up through a hole in the frame cross-member (on each side).
Okay cool. Well, the bell housing I have is in the link that says "bell housing photo" in my last post.
I believe it is 1954. Not really sure which type it would take but if you have something you think may fit, let me know.
Sweet! Is there any way you could send me a photo for reference? That way I'd know what I'm looking for or I could just fabricate something to work like it.
Thanks!
