2 members (David Bush, lumbersawyer), 84 guests, and 3 robots.
Topics128,050
Posts1,055,753
#1098479 04/20/2015 7:12 PM
My '41 1.5 was converted to 12v long before I took ownership of it. I was told by the previous owner that the gauges were 6v but the system is 12v. How is this possible. Has a 12v battery and a 12v generator. I have looked over every inch of wiring and have come to the conclusion that its just a 12v truck.
Is there something I'm missing in my assumption?
I plan on chasing some gremlins in the wiring and solving this will help set the direction.
Also, I went over a bump last summer and all the dash lights went out. I checked the fuse in the switch and it is not blown. Where should I look?
Thanks for the help
Andy
Sometimes you're the window
Sometimes you're the bug
Most of the gauges are mechanical. Oil, Speedo, Temp are all mechanical. Fuel gauge is not voltage sensitive, it is however current sensitive so most folks use a "Runtz" type voltage reducer to protect the gauge. The Amp meter won't care if you run 12 volts or 6 volts. It measures current. To convert from 6 to 12 the minimum needed, is a Battery, Generator, Regulator, Ballast Resistor(for the points), and light bulbs. A 6 volt starter works fine on 12 volts, just don't let it get hot. Light bulbs are interchangeable as far as the sockets are concerned. Dash lights fail, could be a bad connection or a broken wire or an issue with the headlight switch. The dimmer resistor might not like the load with the dash lights.
Steve H
