| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | Does anyone have any tricks for installing the inside window seals on AD trucks? The original beaded seals were attached with heavy staples through the sheet metal inside trim. I am having a terrible time trying to reattach new seals with those heavy staples.
Anyhow, I am just looking for an easier trick for this. Thanks!
Steve 55 1st Series 3/4 ton
| | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | i just used some "weatherstrip aheasive" (same stuff you will use to put on the door weatherstriping) just pull out all the staples, put a lot of adheasive on it, clamp it together, come back the next day.
It worked great on mine.
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | I was not sure if that would work, but now I will definitely give it a try. Thanks!
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Here's a recent thread regarding this subject.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=001698#000007
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2000 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 60 | I USE A # 4 COUNTER SUNK SHEET METAL SCREW. ONCE IT'S IN THERE THE FELT COVER THE HEAD SO YOU DON'T EVEN SEE IT.
FRAMEUP TRUCKS - 47/55.1ST STILL PLAYING WITH TRUCKS | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I make those heavy staples out of welding wire to the same dimensions as the original (made a small jig to bend them). You may have to drill some small holes in the weatherstripping to get the staples through. This worked great on my '57 Chev hardtop but I haven't tried it yet on my truck. Should work the same. | | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | Thanks for the replies. I like the sheet metal screw idea even better. I'll have to give that a try in conjunction with the adhesive.
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I just gave the sheet metal screws a try. Perfecto!!!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
