3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#109833 12/18/2003 4:19 PM
Does anyone have any tricks for installing the inside window seals on AD trucks? The original beaded seals were attached with heavy staples through the sheet metal inside trim. I am having a terrible time trying to reattach new seals with those heavy staples.
Anyhow, I am just looking for an easier trick for this. Thanks!
Steve
55 1st Series 3/4 ton
#109834 12/18/2003 4:41 PM
i just used some "weatherstrip aheasive" (same stuff you will use to put on the door weatherstriping) just pull out all the staples, put a lot of adheasive on it, clamp it together, come back the next day.
It worked great on mine.
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#109835 12/18/2003 5:50 PM
I was not sure if that would work, but now I will definitely give it a try. Thanks!
Steve
#109836 12/19/2003 6:17 AM
Here's a recent thread regarding this subject.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=001698#000007
Craig
#109837 12/19/2003 8:03 AM
I USE A # 4 COUNTER SUNK SHEET METAL SCREW.
ONCE IT'S IN THERE THE FELT COVER THE HEAD SO YOU DON'T EVEN SEE IT.
FRAMEUP TRUCKS - 47/55.1ST
STILL PLAYING WITH TRUCKS
#109838 12/19/2003 3:58 PM
I make those heavy staples out of welding wire to the same dimensions as the original (made a small jig to bend them). You may have to drill some small holes in the weatherstripping to get the staples through. This worked great on my '57 Chev hardtop but I haven't tried it yet on my truck. Should work the same.
#109839 12/19/2003 5:57 PM
Thanks for the replies. I like the sheet metal screw idea even better. I'll have to give that a try in conjunction with the adhesive.
Steve
#109840 12/21/2003 9:26 AM
I just gave the sheet metal screws a try.
Perfecto!!!
grin
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
