1 members (Peggy M), 304 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
#1098308 04/20/2015 12:33 AM
Finally finished putting in a new mc and lines. Bled the brakes and have no leaks. Took the truck for a ride and noticed that I have to press the brake pedal almost to the floor to get the truck to stop. Like a dummy, I don't remember how far I had to press the pedal before the repair job. I've read a couple articles that say with the old trucks you sometimes had to push the pedal to the floor, but I just can't believe that is supposed to be the case. Truck does stop, just not sure if the travel of the brake pedal is normal.
And I'm taking the truck to a pro to have him inspect my work and check everything.
Any thoughts or advice on this is appreciated.
1955 GMC 100 Series 2
what kind of truck?
any modifications besides the new mc and lines?
55.2 on a '78 blazer frame
Single MC
Drums and brakes are from a '78 Blazer and new wheel cylinders were installed in August.
**Already planning on a dual MC build this fall, I could kick myself for not seeing Cletis' write up before starting my brake project"
Firm pedal or spongy? If firm I would look at adjusting the brakes. Spongy I would bleed the brakes until Firm.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Riding in the Passing Lane
A 78 Blazer will have disc brakes on the front. It must have a dual master cyl. to work right.
1972 Chevy c10 Cheyenne Super
This truck has a drum/drum configuration. (it was built by my father-in-law in the 1980's and they did a lot of their own, ummmm, modifications...)
Going to adjust all the brakes tonight and see if that helps. Having a pro look at it as well.
Good plan on having a pro look at it. Make sure to get details as to what he did to fix it so you can do it yourself the next time. We'd like to know too.
Carl
**UPDATE**
Just got the truck back from the shop. They adjusted all 4 brake drums. The front drums needed the most adjustment and since I put new parking brake cables on, that required the rear drums to be adjusted as well. Travel on the brake pedal is MUCH shorter and much firmer. It was well worth the $80.
