1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I was doing some electrical testing & went & left the ign. on. The next day after discovering what I had done I charged the bat. & it would not start. I got to checking for no spark & found it had blown the top almost off the coil. It has petronics igniter with there performance coil. It started with another coil. I'm just glad it didn't blow the module. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 |
| | | | | Joined: Nov 2011 Posts: 1,610 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,610 | George,
Leaving the ignition in the "on" position is to be expected from some of us younger non-mechanic guys, but you?
Seems like this is another procedure from a different time that we have slowly forgotten. With warning buzzers in newer vehicles, leaving a key in the ignition at all is really not an issue any longer.
I think I am going to create a procedure that will eliminate leaving the key in the ignition.
Good to hear that the damage was relatively minor.
Paul | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Good procedure Paul, IS TO JUST TURN IT OFF WHEN YOU WANT THE MOTOR TO STOP!
DG
Denny G Sandwich, IL
