7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51), 160 guests, and 4 robots.
Topics128,089
Posts1,056,129
Members48,435
#967238 08/27/2013 1:34 AM
Hello everyone my name is Brent and let me introduce to you The General, it's a 1953 GMC 9700 grain truck.
[IMG]http://i1325.photobucket.com/albums/u636/Beaster15/DSC00912_zps38428bdc.jpg[/IMG]
I've loved this old truck ever since I was a kid. The truck belonged to my grandpa's brother who was a general in the army, hence why we call it The General. As you can see it's bin tucked away and neglected for quite a few years. The last time it ran was probably 10-12 years ago, my old man was backing it into an old shed with no lights and he caught the wall with the box and killed it. Ever since then it won't start, so I dont know if the timing is off or what the deal is.
[IMG]http://i1325.photobucket.com/albums/u636/Beaster15/DSC00906_zps46fc9cd6.jpg[/IMG]
I figure its time I drag him outta the weeds and try to bring him back to life. My immediate plans are to get it running with long term plans of redoing the wiring and interior and eventually paint, taking off the box and hoist so I hand turn it into a flatbed service truck with an air compressor, generator/welder and slip tanks for fuel.
[IMG]http://i1325.photobucket.com/albums/u636/Beaster15/DSC00910_zpsfde124fe.jpg[/IMG]
First question I have for you guys is I found a maintenance manual for '47-'54 trucks, models 100 through 400, will that be any use to me? Will the wiring from the cab to the front bumper be the same in my truck as it is in that manual? I can't seem to find any info on this series of truck so any help will be greatly appreciated.
Brent
Beaster #967267 08/27/2013 8:44 AM
Looks like a truck smaller than 9700, so the manual you found should be perfect.
What's the weight rating on the tag in the door, the serial number too? I'd guess it'll say 16,000 lb which is a nominal "2 ton" truck.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Beaster #967285 08/27/2013 10:23 AM
3B Offline
Hy Beaster, welcome, a 1953 9700 series would have left the factory with a 248 GMC engine, your truck is powered by a Chevy engine. This could mean that the truck has had an engine swap, or it is actually a 9500 series which was powered by a Chevy 235. If you could post the trucks serial number that would help us to figure out just what has happened, hope that helps.
Beaster #967286 08/27/2013 10:40 AM
Be careful Grigg, Those Canadian built trucks are rated differently than U.S. built trucks. Also those different series designations can confuse a person, if not careful. We need for 3B, to list us a comparison chart, when he has time.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Beaster #967298 08/27/2013 11:32 AM
All the 1954 97xx Canadian GMC trucks (137" - 197" wheel bases) listed in the GMC Canada Maintenance Manual are rated at 18,000lbs.
I scan/post the specifications sheets, if anyone is interested.
Beaster #967305 08/27/2013 12:06 PM
I see,
Completely missed the Canadian part of it. I opened the thread expecting to see a big GMC tractor like a long nose 900 or 9000 series with a 6-71 under the hood and was a little disappointed to see a little 2 ton truck (approximately).
Thanks for the clarification,
Grigg
---All pictures---
Beaster #967311 08/27/2013 12:30 PM
Model: 9783-HD
Serial: 3978303164
I've done a little research in decoding the serial number and this is what I've come up with. (no idea if I'm bang on or completely wrong)
3=1953
9=GMC
7=3 Ton (9700)
8=179" wheelbase
3=cab
03164=3164th truck built in 1953
Engine:G43016
Body serial:332
Paint:330
Trim:394
And its rated for 17500 lbs
Beaster #967355 08/27/2013 4:07 PM
3B Offline
Hy Beaster, it looks like you have deciphered your serial number correctly, that engine serial number is correct for a Canadian GMC 248 engine, but your pictures clearly show a newer Chevrolet engine in the truck, so the engine has been replaced at some point. You will probably find some kind of adapter plate at the front of the engine which bridges the gap between the GMC engine mount on the chassis and the shorter Chevrolet engine, hope that helps.
Beaster #967375 08/27/2013 6:50 PM
Thanks for the info 3B, so that's a Chevy 235 engine in there? I know absolutely nothing about either of those engines so can a guy still find a manual for that 235?
Beaster #967467 08/27/2013 10:52 PM
3B Offline
Hy Beaster, that 235 was used from 1954 until 1962, there is plenty of info around about them, put an ad in the parts wanted forum to see if anyone has a Canadian maintenance manual.
Beaster #1098076 04/18/2015 5:37 PM
Alright guys I finally got back around to getting the serial number off the engine (right behind the dipstick) but I'm having trouble trying to decode it. I'd appreciate some help on showing me what I have for sure for an engine.
It looks like to me P-644685 and then beside & below that it looks like 88 5
http://s1325.photobucket.com/user/B...amp;_suid=142937481437505749212868520439
Beaster #1098143 04/19/2015 2:16 AM
3B Offline
Hy Beaster, if you could take a picture of the engine above the starter and the water pump area that would help us to determine the year and tell us whether or not the engine is a 235 or a 261. Unfortunately I have never seen a list of Canadian Chevrolet engine serial numbers.
Beaster #1098231 04/19/2015 4:29 PM
Thanks 3B, I'll try and get some pictures tonight after I get home from work.
Beaster #1098248 04/19/2015 7:20 PM
Crusing in the Passing Lane
When you get to the engine, any GMC (228-302) will fit right in there, unless someone has made mods. For the Chevy engine. Parts for 270-302's are easier to find then smaller engines.
Beaster #1098386 04/20/2015 4:54 AM
I took 10 pictures of the engine, I hope that was enough grin I'll just post the link to one picture and you can scan through the other in my photobucket account.
http://s1325.photobucket.com/user/Beaster15/media/IMAG0420_zpsilmt8q5r.jpg.html
Thanks in advance fellas
Beaster #1098417 04/20/2015 2:09 PM
I'd like to spray the whole engine bay with degreaser and wash everything with a pressure washer to remove the oil and grime so I can get a better look at things. Can I do that without worrying about wrecking anything as long as I don't get any water in the air cleaner, or am I just looking for problems if I do that?
Beaster #1098424 04/20/2015 2:49 PM
Be careful with high pressure water cutting the insulation off of your old wiring harness. Other than that you should be ok.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Beaster #1098437 04/20/2015 3:40 PM
3B Offline
Hy Beaster, it looks like your engine is a 1955 through 1962 235, hope that helps.
Beaster #1098468 04/20/2015 6:40 PM
Awesome thanks guys.
