5 members (klhansen, tesa, Gdads51, treegrower, carbking), 71 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,430
#10966 05/25/2005 4:44 AM
I was doing some searching, but was not having much luck, if someone could point me in the right direction I'd appreciate it
#10967 05/25/2005 5:34 AM
"MONGO"
"MONGO"
Langdons sells em, I'm running one in my truck, I've also read that you can modify your own early 80's S10 V6 HEI Distributor, I can look for the directions for you if your interested.
Langdon sells em for $160 - Mini HEI
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#10968 05/25/2005 1:31 PM
Turn down the clamping flange on a HEI from almost any 6 cyl chevy, shorten the oil pump drive shaft, fabricate new mounting clamp, install, supply 12 volts, fire up, drive.
It helps if you have a lathe to turn down the flange, but a hacksaw, a file, and a careful hand will work.
#10969 05/25/2005 4:25 PM
I have a mallory electronic no points on mine,, from patricks,, not cheap but has worked well for over 8 yrs,,,,,,,,,,,,Fred
Redryder pix
My Hotrod
#10970 05/25/2005 5:56 PM
I am new to the discussion board, and have followed closely the topics on the 235's with much interest.
Will be pulling the engine from my 54'Vette that I recently purchsed and will begin restoration on. I believe the engine I have now is from a truck (#3739716 B-19-02). Anyways I want to "beef up" the old 6 a bit this winter when it is to be rebuilt - with an HEI system as a possible option. Problem is the distributor on the engine now is an aftermarket replacement. I need to find a distributor with a tach drive since that is what was origionally on the car.
Anyone know if there are 6 cly. HEI's with a tach drive? Don't mean to bellyache but WOW - can't believe what the "asking" price for a early vette tach drive distributor let alone the water pump, generator, starter. I know this 235 will serve me just fine....
Thanks!!
#10971 05/25/2005 7:39 PM
The HEI has an electric tach connection. Does this count?
#10972 05/25/2005 9:47 PM
One other possibility is to install a Pertronix module in the points distributor. That way you still retain the vintage look.
Fred
52 3600
69 C-10
#10973 05/25/2005 9:51 PM
54 Guy - If you intend going for an NCRS points car then I'm afraid you really have no alternative except to bite the bullet and put the coin down. All the 'vette parts are out of sight which is why my 62' is a driver and not a show car.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#10974 05/25/2005 10:16 PM
Jim Carter sells low cost modified HEIs at oldchevytrucks.com for $250.
Patrick Dykes sells an electronic mallory at patricksantiquecars.com for $325.
Nick Zaillian sells an electronic mallory with vacuum advance at waynemfgco.com for $650.
Mike Barnes
1950 GMC 1-ton pickup
#10975 05/26/2005 1:29 PM
Or you can get a junkyard dizzy for next to nothing and rework for almost as little.
One of the best things I did to my truck. I hate points.
#10976 05/26/2005 4:37 PM
train driver - could you send me a little more detailed info on what you did to modify that distributor? email = [email protected] - maybe some pics if you them?
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#10977 05/26/2005 5:12 PM
Langdon's Stovebolt 586-739-9601... Mini HEI for $167.50 which included the shipping. Nice guy... real helpful.
Larry Bear
55.5 Chevy 3100 Panel
#10978 05/26/2005 8:04 PM
Give me some time, I'll be on the road this weekend. It is deceptively simple. If you get your hands on an original dizzy and lay it next to an HEI, it becomes obvious what has to happen. The most difficult item is the clamp to hold the HEI in place.
#10979 05/27/2005 3:52 AM
Train driver I'd also like some info on this. I just want to keep my 235 reliable while I build my new frame/driveline
right now I have rebuilt the engine from the deck up and added an offenhauser dual carb intake,(not to easy considering how close the hood comes to the engine) not as much room as the trucks and older cars
#10980 05/31/2005 12:47 AM
Junior Member
Junior Member
I bought a 74 Impalla HEI distributor at a yard sale for $20.00. It fit right in my 63 292 and has lasted over 20 years! Don't waste your money on over the counter parts. Check a junkyard for a 74 Hei first. If it works keep using it!
Rastusman
#10981 05/31/2005 1:35 AM
Tab Offline
Rastusman:
Will that 74 Impala distributor work with a 235?
delete my account and pictures
#10982 05/31/2005 2:46 PM
Junior Member
Junior Member
I would say (probably) yes (they are the same stock shortblock). I haven't tried the 235 (yet)! Anyone else with a more informed answer, please feel free to chime in.
Rastusman
#10983 05/31/2005 4:58 PM
Junior Member
Junior Member
get a pertronix drop in electric ignition.
It's works great, not more points and the truck's dist. looks original. http://www.pertronix.com/
