9 members (Bill Hanlon, Uncles51, FAST55, gswbbc, Hanks custodian, Hotrod Lincoln, sron48, 2 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,480 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | This hobby is very addictive. I picked up another truck it's a 1947.5 chevy 4400 shortened with a dump box on it. Running 235 splasher. Was suppose to be parts truck for my 51 but now I'm not sure what truck I'm gunna build kinda like both the three window and the five window trucks. The 47.5 has a deluxe red head heater not sure what that comes from but it works. I guess pick the best parts and see what happens not really a plan yet.
Is there any pro and cons between 47.5 and the 51 trucks?
1947.5 Chevy 4100 red primer 1951 Chevy 4400 grey primer
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Pros & Cons are in the eyes of the beholders.
Other differences: - fuel tank location (in-cab or under-bed) - left-side lower-cowl open/close air-vent vs vent windows - wider seat in the 51
As crenwelge posted: " I would use the one with the least rust. " I'd pick the one with the less cab rust. Check carefully around the interior cab floor and the lower rear cab corners (poke with screwdriver).
| | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | The 47.5 definitely has the better cab and front fenders and dump box. The 51 has better frame but I do like both the driver side vent and vent windows might be showing my belt buckle and suspenders again like hotrod lincoln said about my transmission idea or just keep the windows and block the vent
| | | | | Joined: Jan 2015 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 7 | N-man hear. I am very new to this also, but had to laugh. I first bought a 51 1.5 ton and 6 weeks late got a 48 2 ton for parts. I don't have a plan yet either except to take the best of both and make one....I will be fun to see how our two very similar projects will shape up.... | | |
