8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10966 05/25/2005 4:44 AM | Joined: Mar 2004 Posts: 37 New Guy | | New Guy Joined: Mar 2004 Posts: 37 | I was doing some searching, but was not having much luck, if someone could point me in the right direction I'd appreciate it | | |
#10967 05/25/2005 5:34 AM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Langdons sells em, I'm running one in my truck, I've also read that you can modify your own early 80's S10 V6 HEI Distributor, I can look for the directions for you if your interested. Langdon sells em for $160 - Mini HEI Mongo | | |
#10968 05/25/2005 1:31 PM | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | Turn down the clamping flange on a HEI from almost any 6 cyl chevy, shorten the oil pump drive shaft, fabricate new mounting clamp, install, supply 12 volts, fire up, drive.
It helps if you have a lathe to turn down the flange, but a hacksaw, a file, and a careful hand will work. | | |
#10969 05/25/2005 4:25 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I have a mallory electronic no points on mine,, from patricks,, not cheap but has worked well for over 8 yrs,,,,,,,,,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#10970 05/25/2005 5:56 PM | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | I am new to the discussion board, and have followed closely the topics on the 235's with much interest.
Will be pulling the engine from my 54'Vette that I recently purchsed and will begin restoration on. I believe the engine I have now is from a truck (#3739716 B-19-02). Anyways I want to "beef up" the old 6 a bit this winter when it is to be rebuilt - with an HEI system as a possible option. Problem is the distributor on the engine now is an aftermarket replacement. I need to find a distributor with a tach drive since that is what was origionally on the car.
Anyone know if there are 6 cly. HEI's with a tach drive? Don't mean to bellyache but WOW - can't believe what the "asking" price for a early vette tach drive distributor let alone the water pump, generator, starter. I know this 235 will serve me just fine.... Thanks!! | | |
#10971 05/25/2005 7:39 PM | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | The HEI has an electric tach connection. Does this count? | | |
#10972 05/25/2005 9:47 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | One other possibility is to install a Pertronix module in the points distributor. That way you still retain the vintage look.
Fred 52 3600 69 C-10
#10973 05/25/2005 9:51 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 54 Guy - If you intend going for an NCRS points car then I'm afraid you really have no alternative except to bite the bullet and put the coin down. All the 'vette parts are out of sight which is why my 62' is a driver and not a show car. | | |
#10974 05/25/2005 10:16 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Jim Carter sells low cost modified HEIs at oldchevytrucks.com for $250.
Patrick Dykes sells an electronic mallory at patricksantiquecars.com for $325.
Nick Zaillian sells an electronic mallory with vacuum advance at waynemfgco.com for $650.
Mike Barnes 1950 GMC 1-ton pickup
#10975 05/26/2005 1:29 PM | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | Or you can get a junkyard dizzy for next to nothing and rework for almost as little.
One of the best things I did to my truck. I hate points. | | |
#10976 05/26/2005 4:37 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | train driver - could you send me a little more detailed info on what you did to modify that distributor? email = [email protected] - maybe some pics if you them?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#10977 05/26/2005 5:12 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Langdon's Stovebolt 586-739-9601... Mini HEI for $167.50 which included the shipping. Nice guy... real helpful. | | |
#10978 05/26/2005 8:04 PM | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | Give me some time, I'll be on the road this weekend. It is deceptively simple. If you get your hands on an original dizzy and lay it next to an HEI, it becomes obvious what has to happen. The most difficult item is the clamp to hold the HEI in place. | | |
#10979 05/27/2005 3:52 AM | Joined: Mar 2004 Posts: 37 New Guy | | New Guy Joined: Mar 2004 Posts: 37 | Train driver I'd also like some info on this. I just want to keep my 235 reliable while I build my new frame/driveline
right now I have rebuilt the engine from the deck up and added an offenhauser dual carb intake,(not to easy considering how close the hood comes to the engine) not as much room as the trucks and older cars | | |
#10980 05/31/2005 12:47 AM | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | I bought a 74 Impalla HEI distributor at a yard sale for $20.00. It fit right in my 63 292 and has lasted over 20 years! Don't waste your money on over the counter parts. Check a junkyard for a 74 Hei first. If it works keep using it!
Rastusman
#10981 05/31/2005 1:35 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Rastusman:
Will that 74 Impala distributor work with a 235?
delete my account and pictures
#10982 05/31/2005 2:46 PM | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | I would say (probably) yes (they are the same stock shortblock). I haven't tried the 235 (yet)! Anyone else with a more informed answer, please feel free to chime in.
Rastusman
#10983 05/31/2005 4:58 PM | Joined: May 2005 Posts: 12 Junior Member | | Junior Member Joined: May 2005 Posts: 12 | get a pertronix drop in electric ignition. It's works great, not more points and the truck's dist. looks original. http://www.pertronix.com/ | | |
