2 members (klhansen, 1 invisible),
151
Mod | | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | I need to know whether I should remove all of the running board mounts before sandblasting to get at the rust under them. Is this really that big a deal or just a technicality? On the same note do the shock mounts need to come off too? Thank you! | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I did not remove my RB bracket when I prepped my 54 frame. The left rear bracket had to be removed to fix some frame rot but is now bolted back on with grade 8 hardware. The shock mounts should not be a problem either unless there is frame rot behind them now. | | |
