0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Looks like the Colorado/Canyon five cylinder engine. My nephew has an 04 Colorado with 355,000 miles on it and still running strong. They get 25mpg and although not a neck snapper they aren't embarrassing. A turbo and other goodies will kick them up to about 400hp at the rear wheels. Hope you post progress photos as this is an interesting thread. We have a 4.2 six cylinder from a Trailblazer and after seeing your photo it may have just found a new home.
Evan
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You're close. It's a 6 cylinder Vortec 4200. I do have a Colorado/Canyon 5 speed behind it.
To be quite honest the 5 cylinder would be a much better engine to swap. Eveything is really tight with the 4200. Knowing what I do now, I think I'd look for a wrecked Colorado/Canyon. I'm going to have to trim the front crossmember slightly to make it work. If I had a 47-55 GMC, there wouldn't need to be any trimming done at all.
Also, the oil pan for the 4200 is going to need to be notched to clear the front axle. The way it looks, I don't think I'm going to have to convert it to a rear sump.
The upper coolant outlet on the engine is going to need to be shortened too. I'm hoping it's aluminum and not pot-metal so my Aluminum welder can shorten it.
| | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | Just a note.. there is an aftermarket rear sump oil pan for the 4200. This makes the installation a lot easier. www.vortec4200.com for all things related to the atlas engine ( this is GM's name for the 4200 and its smaller siblings). | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Nice tid bit of information there; thank you
Evan
