3 members (Otto Skorzeny, Rusty Heaps, Steelonsteel), 108 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#1097581 04/15/2015 6:26 PM
i just got my frame back from sandblasting
now what kind of paint should i use
on the frame,thanks keith
U
U Offline
Is it coated with anything? Or was anything done to neutralize any rust that was on it?If it is just bare metal, nothing coated on it, you'll need to wipe the whole thing down with lacquer thinner or maybe acetone to remove as much dust as possible before you coat it. Air gun it off if you can.
I 'painted' my frame with the POR15 product...
It has held up fine (since Oct '14), it was easy to use, but I would have blasted/epoxy-primed/epoxy-painted my frame if I had to do it again. Or have it powder-coated.
I've sandblasted off some POR15 that was 100% correctly applied recently; it is easier to get off than the epoxy primed/painted stuff. This is just my opinion & don't get me wrong- the POR15 looks great and is hard to get to chip...
Just knowing now what I did not know then (Oct), I'd either rattle-can the frame, epoxy it, or have it powder-coated.
Brad
Edit- In the end, it's just the frame... you need to get the rust off (check) & paint it. As long as you do not introduce any adverse chemical reactions, almost all of today's painting products are comparable or better than the paint that came on it.
Wrench Fetcher, PhD
3 coats of a good epoxy primer.
If you were to search other forums you'd find strong support for PPG and Southern Polyurethane Inc. or...SPI
For the price it's hard to beat SPI.
If your worried about 'durability' watch this test made by some guy on youtube who wanted to decide for his own peace of mind.
I'm still waiting to see someone do a head to head test of PPG and SPI.
Give me ambiguity
or give me something else
If the sandblasting has removed all traces of rust, you should not need any rust conversions or rust encapsulating paints. The sandblast finish is perfect for mechanical adhesion of any good epoxy primer. If you are looking for a good semi-gloss black, SPI epoxy will give you a good durable finish and has UV inhibitors, so once sprayed you should be done.
For prep, I would use a bucket of warm to hot water with a light Dawn soap mix, using a Scotchbrite pad dip in the bucket, scrub an area, and dry with a towel. Move to the next area and repeat, using a slight overlap. Once done, clean with a pre-clean solvent, then tack cloth to remove any lint.
Hopefully you degreased the engine area prior to sandblasting, but I would caution against using lacquer thinner as a cleaning solvent. It evaporates too quickly and risks leaving impurities behind. Use a pre-clean solvent, which is slower to evaporate. The premise behind cleaning with a pre-clean is similar to the wax-on, wax-off. One rag with pre-clean applies, the slow to evaporate solvents will "float" any impurities to the surface where rag number 2 is used to wipe it off. On sheet metal, I usually apply on about a 2' or less square, allow about 15-30 seconds for impurities to float, and then wipe with second cloth. If pre clean is drying before you have a chance to wipe, either use wetter application cloth or smaller area. You want to wipe before drying as otherwise you have floated impurities and once cleaner dries, the impurities are right at the surface, they don't magically disappear......regardless of what you use.
Given the cost of paints, I normally do the pre-clean process at least twice. Good insurance policy to help eliminate chance of fisheye..
On the cheaper cans of lacquer thinner that most hardware stores carry, these are recycled solvents that will contain who knows what. Get the product designed for cleaning the bare metal..
The 48 2 ton was sandblasted and powder coated.
Not only does powder coat get into all those nooks and crannies that are a bear to get spray into, but the the finish is much more durable than paint.
Recently, while doing brake work, some brake fluid got squirted on the frame and tie rod. It ruined the paint on the tie rod, wiped off the frame powder coat without a mark.
thanks for all the info guys
you all have been very helpful
thanks keith
