7 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon), 51 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
Can I put a reverse lockout lever on sm420 trans? I have a 47 with the lockout and a 1951 with e-brake on driveshaft I know the two trans are like apple and oranges just wondering if it's possible kinda like that feature
1947.5 Chevy 4100 red primer
1951 Chevy 4400 grey primer
The SM420 has a spring loaded reverse gate but it would be possible to add the lockout with some tinkering with the shift lever. You would need a pivoted plate mounted to the shift lever that prevents the shifter from moving into the reverse position by blocking its sideways movement. It might be necessary to modify the twist cap at the top of the transmission tower, also. Having both the spring and the lockout lever is sort of like wearing a belt and suspenders to keep your pants from falling down, isn't it?
Thanks Jerry, Guess I like to show off my belt buckle and stripes on my suspenders yahoo
