3 members (Otto Skorzeny, dt235sd, Rusted Nut), 80 guests, and 2 robots.
Topics128,048
Posts1,055,664
#1090025 03/07/2015 4:01 PM
Getting ready to put the cab back on my 41GMC COE and I'd like to get all new cab mounts and springs. I'm assuming that I can use the kit from a pickup and will just have some left over? I'd just call the company and ask, but the last time I did they told me to talk to"Spanky".
Crusing in the Passing Lane
One can also use rubber grader blade material(for snow plows) which comes 1" x 4" around here, might have to search around a bit, hydraulic shops carry it around here.
Are you talking about just bolting directly to the frame with the rubber in between? If so, I was thinking about doing this but the frame flexes so much it seems like it would eventually damage the cab?
The COE cab mounts the same to the cab 'riser' as the 1/2T cab bolts to the frame. Just use the smaller truck kit. You don't actually have left-overs. Same mounting holes and bolts as the COE... just different sills.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
Thanks Tomcoe. I have since figured out the bolt lengths and rubber padding for the front mounts. I did not realize the back sat on a wood strip. Just hadn't got into it that far. I have it bolted back on now and will replace with grade 8 as I clean up and paint.
