3 members (78buckshot, crenwelge, 1 invisible), 79 guests, and 2 robots.
Topics128,062
Posts1,055,851
Members48,428
#109675 03/09/2005 7:32 PM
I have a 1954 frame with camero front suspension,question is ,how much trouble would it be to put a 1951 body on this frame, both frame and body are in very good condition,. is this possible? and how much work and time is envolved?
#109676 03/09/2005 8:00 PM
Anonymous
Unregistered
Anonymous
Unregistered
The earlier cab, running brds and front sheet metal should bolt right up to the 54 chassis. The one difference I am aware of between the 54 frame and earlier models is at the rear of the frame but I think you can get either bed to fit.
#109677 03/09/2005 9:50 PM
The bed mounts are quite different, but I'm sure it wouldn't be too much of a PITA to fab up the proper mounts. If you have the '54 bed, I'd stay with it - it was well-designed enough that it was used with only cosmetic differences from '54-'87.
1954 GMC De Luxe COE
