8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 10 New Guy | | New Guy Joined: Feb 2004 Posts: 10 | I have a 1954 frame with camero front suspension,question is ,how much trouble would it be to put a 1951 body on this frame, both frame and body are in very good condition,. is this possible? and how much work and time is envolved? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The earlier cab, running brds and front sheet metal should bolt right up to the 54 chassis. The one difference I am aware of between the 54 frame and earlier models is at the rear of the frame but I think you can get either bed to fit. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The bed mounts are quite different, but I'm sure it wouldn't be too much of a PITA to fab up the proper mounts. If you have the '54 bed, I'd stay with it - it was well-designed enough that it was used with only cosmetic differences from '54-'87. | | |
