3 members (Chip O, Hotrod Lincoln, Uncles51), 90 guests, and 1 robot.
Topics128,029
Posts1,055,417
Members48,422
Page 2 of 2 1 2
jacksun #1084655 02/09/2015 6:30 PM
Tim,
You are not crazy or alone! I just double checked my '49 3100 and I also have the tracked door weather stripping and the welded in cab ceiling support with holes for a screw in headliner. I'll have to go back and look for the holes in the sides of the dash that Brad posted the pictures of earlier.
I think both our trucks are definitely case of mixed configurations from a mid year change.
- Pat
Fish63080 #1084699 02/09/2015 10:40 PM
Brad, Carl and Pat,
I had a long conversation with Jeff from Bowtie Bits. I think Jeff has cleared up the confusion on the headliner center bow. Jeff told me that 5 years ago he had a very late production 1949 truck in his shop with the same configuration I have for the headliner and center bow. The key is that it is a VERY late production '49 3100 and that the screw in center bow was used up until 1950. The problem I have with the screw on center bow I removed from the truck is that at some point in time someone cut the ends of the center bow. Why....we don't know. The proper screw in center bow for a VERY late production '49 slips under the channel type wind lace just as the floating bow does. He measured the screw in center bow I purchase from him and it is 1 1/2" longer on each end, which should well slip under the channel type wind lace. Jeff also told me from what he has seen over the years is that the lower cab wind lace on the 1947-mid 1949 trucks screwed in from the sides and the VERY late model 1949- 1954 screws in from the top and is attached with the step sill plate? I'm getting there. Hope this info is of some help!
Thank you guys for ALL you help and advice......
Tim
1970 VW Beetle
fixit1958 #1096635 04/10/2015 6:15 PM
UPDATE!! Ok, I've got my new late '49 headliner installed from Bowtie Bits with a lot of patience and cursing. I'm with Denny and Gus, these reproduction headliners no matter where you get them seem to be cut short on the width. Mine was short on the passenger side front by 3/16" and the rear section was about 1/4" short on the drivers side where the rear most curve around the top door meets with the headliner. I also tried the headliner I purchased from JC and the results were the same. Thanks to Gus (DADS50) for the tip on covering the gaps. Doesn't look to bad, so it worked out as best I could get it. For the ones that popped these headliners in and they fit perfectly in a half hour or less.....I envious!
1970 VW Beetle
Page 2 of 2 1 2
Moderated by  ndkid275, Phak1
