8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | I am often asked what is the float setting for Zenith carburetors. The standard answer has been (and this is published in some Zenith literature) "if one installs a new float and new fuel valve, then the float is properly adjusted".
Was reading through some obscure confidential Zenith bulletins yesterday, and actually found some printed measurements for Zenith float settings. The ones normally used by members of this forum would be the downdraft series 23, series 28, and series 228 carburetors.
With the float closing the fuel valve, the distance from the BOTTOM of the float to the casting surface WITHOUT gasket:
23 series - 1 1/2 inches 28 series - see edit below
EDIT: the 1 21/64 previously posted should be 1 31/64.
This bulletin was written before the 228 series was released, so no additional information on the 228 series.
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | What is the source of that 1 21/64ths?
My book says 1 31/64th +/- 1/32 for 28 and 228 series Zenith carbs.
One book specifically reference the 228s
Another book is pre-228s (28 Series).
None of them call for 1 21/64
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | The 1 21/64 is in the book of old age and crooked fingers!
Sorry.
The correct figure is 1 31/64.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
