2 members (Patharr, 1 invisible), 45 guests, and 3 robots.
Topics128,090
Posts1,056,027
Members48,432
#1096441 04/09/2015 4:58 PM
Hello,
Does anyone have any tricks to holding the clutch plate in place while tightening the cover? Or, do I have to buy the tool?
Im working with a 235, 1955 engine.
Judson
Judson,
If you are lucky enough to have an old transmission, you can remove the front shaft and use it as an alignment tool.
Many clutch-assembly sets include a plastic alignment tool (as shown at the link above).
You could place a Want Ad in the Swap Meet and ask to borrow an alignment tool (and pay for shipping).
You could put a city name in your Profile "Location" and someone nearby might offer to lend you a tool.
I could loan you a tool but "California" is a big place.
Fred
any auto parts store sells the alignment tool, that you just stick thru the clutch disc and into the pilot hole
Riding in the Passing Lane
The old trans shaft works better than the plastic ones. I have an extra plastic 1 or 2 around I can send you if you PM or e-mail me an address.
George
1972 Chevy c10 Cheyenne Super
I'm with George on that one, the input shaft from an old tranny works better than them plastic ones.
Brian
1955.2 3100 Truck
Thank you, Tim.
I actually do have the orig. 1941 tranny. I looked at it this morning, and it appears to just come off with 4 bolts.
I think Ill take your suggestion, pull it off, and use it for the guide.
Will it need a new gasket at that point? I assuming the trans oil will all come out at that point...
Sometimes the input shaft will pull out and sometimes the gear hangs on the cluster gear and it won't come out. Either way you will lose the needle bearings inside the input shaft when you pull it out. If the lube is drained I guess you could stand the tranny on it's front end while pulling the input gear and have gravity on your side. Heavy grease will hold the needle bearings to slide it back in.
Evan
Judson #1096687 04/11/2015 12:11 AM
I would not pull an input shaft out of a good transmission - just to use it as an alignment tool, unless you will be getting rid of that transmission.
ok. Got it. Thank you. Ill just pick one up. They look rather inexpensive. Judson
I paid $10 bucks for mine, and it probably was one of the best things I spent $10 on, and it is reuseable.
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Indy...can you post a link on where you bought the correct tool. I'd like to just buy one, don't have the time hunt one up in a salvage yard. Which one is the correct one?
Allen
1974 Stingray Corvette
the price dropped by half but this is the one i got to install my SM420
http://www.oreillyauto.com/site/c/d...earch_tat5301_-1_183&keyword=tat5301
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
H Online: Content
All the broomsticks in my shop ended up several inches short- - - -cut off a section of handle and whittle it down to the right size to act as an alignment tool!
That'll work, $5.
Allen
Originally Posted by Allen Lane
That'll work, $5.
Referring to Materman's post about the O'Reilly's part: Pioneer Inc. - Clutch Alignment Tool
Part # TAT5301 ($4.99)
you'll need to take the clutch in with you to match the splines on you're clutch there are many different ones.
Pete
I have used my plastic one with the cone several times and it worked just fine.
1951 1 Ton Completed
Thanks, everybody!
