0 members (), 129 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
rwb
Offline
anyone know if a 1971 1/2 ton gmc rear end would work on a 1958 1/2 ton.i am not even seeing spyder gears
for sale for 1958. maybe I should just find another
rear end ?? any other year suggestions ??
thanks
There is a way to save the original rear, but it might be a little spendy. Tom's Differentials has an axle shaft conversion for the '55-'59 rear end that changes it to the later 30 spline shaft. That will allow for the later 12 bolt spider gears to be used in the housing.
Bill Burmeister
Sir Searchalot
Sir Searchalot
It is cheaper and better to just use a donor from a newer truck. Done it several times. Just measure your WMS-WMS and search internet info to find some that come close. Then buy one on Craigslist. Be sure to open it up before buying to inspect gears and ratio. $100-$200 for open diff. Easy install. Some shock mount mods may be necessary.
Supposedly: NOT verified,
69 and some 70's 62 1/4"
71-72 and some 70's 63 3/4"
1955-1959 Chevy Pickup 62"
A little wider is OK and can be compensated with
Backspacing/off set adjustment.
rwb
Offline
thanks all I will cont looking for another rearend
bring a tape measure with me!!
Sir Searchalot
Sir Searchalot
Good deal.
rwb
Offline
what do you mean by backspacing. different rims ??
do you happen to know if u bolts same as I just ordered a set before I found out the other 59 rear
end also has excessive spider gear play.
thanks
Sir Searchalot
Sir Searchalot
Originally Posted by rwb
Part 1:what do you mean by backspacing. different rims ??
PART 2: do you happen to know if u bolts same as I just ordered a set before I found out the other 59 rear
thanks
Part 1: Yes, different rims may bring a wide or narrow WMS back to looking acceptable.. or live with it.
Part 2: If axle tube is same diameter (3"?) and using same springs and plate....yes.
