1 members (1 invisible),
91
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | The spare tire is located under the bed of my 1948 Chevy 3100. My problem is I do not have a key to release it. I hate to cut it if I don't have to preserve it. I tried a locksmith with no luck. Does anybody have any suggestions, is there a master type key, possibly know the key number, etc.. | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | All of the under bed spare tire holders that I have ever seen were bolted. Someone may have used a padlock of some kind for security. If it is a pad lock just cut it and buy another with the key. | | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I am referring to the lock on the J hook. I can find a new J hook easily if I have to cut it and a replacement nut but the nut requires the original facrtory spare tire lock (which I have no key for). I don't want to buy a complete aftermarket holder, $300, just to get a new j hook and key lock. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have one of these VERY VERY hard to find locks that were made specially for the 47-55 under bed spare tire carrier. The key is the same type as the ignition and glovebox. Try another locksmith, then another until you get the guy who knows what to do. Do not mess up that lock!! Its like gold. I'm not sure $1000 would be enough to sell it. Those who had them back in the day hated them to a purple passion. Why? Imagine a rear flat. Not only can you not get to the spare tire, but now you have a lock that has had mud and crud slinged all over it for years. By the time you have lost your head, over-handed the spare tire carrier lock out into the field, tossed the spare tire carrier in the ditch and threw the bad tire in the bed, you never looked back. So, if you can find them, its with a metal detector in the field, or ebay or the like and I havent seen them in years. Home page here has a pic of what he is talking about: www.devestechnet.com | | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | Does your key have any kind of number on it or something to give a locksmith a clue? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | no. but its the same key stock that was used for the ignition and glove box. If they say they can do your ignition or glove box, they can do your carrier lock. No numbers on the key, but you are welcome to take that high rez picture to them so they can see its the very same.
There is a very large spectrum of locksmith out there. Some are very very good and think of their job as more detective work. Others need a manual and don't care. Try about 4 other locksmiths before you give up, THEN think twice. Its just a standard late 40's early 50's lock. Look for an older locksmith. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I agree with Deve, SAVE that lock, they are very rare. I've been looking for one for ten years and never have run across one. You're thinking in the right direction as far as cutting the J-hook. That's easy to duplicate and no one would know the difference, even the nut can be duplicated but the lock is really special. If it's a daily driver and your worried about getting crap kicked up in it, I'd just coat it with a good heavy coat of grease once in a while. That would keep the dirt and water out of it, just wipe it if you needed to open it. J-hook pattern: http://www.pbase.com/dennygraham/image/159630923dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have one of these VERY VERY hard to find locks that were made specially for the 47-55 under bed spare tire carrier. . . In case someone wants to join the hunt for the lock, the same lock assembly was supposedly used from 1941-1950. No under-bed spare lock (that I can find a part number for) was used from 1951-1955 (there was a 53-55 bed-side tire carrier lock - scarcer than the earlier under-bed lock). | | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | Deve, which high res picture are you referring to? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim, do you have a picture or illustration of the side mount lock? I don't have any accessory sales literature for the later trucks. Every time I spot a different lock design for a hitch bolt I buy it. I must have six or eight around here. Been looking for one that I could scavenge the locking tumbler out of that would work the same as the original under bed accessory. I've looked into machining the lock housing out of a solid block to look like the original one but can't find a tumbler that would work the same as the GM one. I've also got side mounts on both trucks and would like to see a lock that was meant for them. tks DG
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The picture on the main page of the website. It shows two keys and they can see its the same as your ignition and glovebox. http://devestechnet.comRight click and "Save As" | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Also, I checked today for numbers on those keys. There are none. The text in the spot where you would think they go say something about cutting out the center. So no help there. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Those key are ladies in waiting Gus, blanks just waiting to be assigned.
Thanks Tim, that's the catalyst I needed. That is obviously for a GMC and no doubt the same as the Chevy, but where did you get that from???? I see the heading says 'classified'?
Now that I see it, that side mount lock could easily be reproduced using one of the 5/8" dog bone locking trailer hitch pin tumblers. Just need to pick one with key's similar to the GM Briggs key. The housing, nut and nut retainer could easily be made to look just like an original one. The cover could be whittled out of an aluminum chunk in the band saw and finish machined in the Bridgeport or maybe Cast? In fact that part is the perfect project for the five gallon aluminum furnace that I've been waiting to put together and try my hand at aluminum/zinc casting. The lock housing is a simple machining project to accept the donor tumbler and I've already whipped up some nuts similar to those for my under bed carrier. Thanks, just what I need, another project, well that's what I get for askin'!
Denny G
