9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | No blown head gasket thank goodness. But truck sputters in 3rd gear only. .. any suggestions? Also where is the Trans refill cap? That's the only fluid I haven't changed. 216 motor
1964 impala ss 1949 chevy 3100
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Timing could be off a smidge for the sputtering, or could be the points- is this original/stock distributor setup with a vacuum advance?
Full tune up usually solves a "sputter" if it's not trash in the carb.
Brad
Wrench Fetcher, PhD | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | upgraded to pertronix electronic ignition. Just got mufflers put on and wasnt doing this before. Also new gas tank, freshly rebuilt zenith. It only does it in 3rd gear?....wierd
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I can't help you with the pertronix (no experience there), but since there's a new muffler in the equation, I'd look there. It may not be allowing the engine to "exhale" as well as it needs to be. (Me thinking out loud here, and only speculating:)You may have to reset everything to allow for the changes in the exhaust gas release. Again- that is me speculating, but it does make sense.
I did have a mouse house in my exhaust pipe once. It caused a little more than a sputter, though. Hopefully, somebody will come along soon & give you some pro tips on where to look.
Brad Wrench Fetcher, PhD | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What procedure did you use to adjust the carburetor?
What procedure did you use to adjust the timing?
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Got it up to operating temp then turned mixture screw in until engine started to stumble then backed out quarter of a turn
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sorry - my second question was a duplicate - I changed it.
How did you set the timing?
Your mixture setting should be OK, but if you have a vacuum gauge, try setting the mixture to maximum vacuum.
Try setting timing to maximum vacuum.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | I haven't moved timing and runs fine just don't want to accelerate
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | If your ball is on the pointer at idle, check your counterweights inside the distributor, or check your total advance at 2,000 RPMs with an adjustable timing light (if you have one). Carl
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | pking75- from the other thread: The little tune ups make the biggest difference I know you you have the pertronix, but a tune up solved heavy40chev's issue. It's a process of elimination sometimes. First off, try setting your timing to maximum vacuum as Tim suggested. If you didn't move the timing, and it "runs fine" I'm a little confused why it won't accelerate properly...unless your vacuum advance has lost its vacuum- making it not advance the timing. The vacuum advance is a mechanical operation and independent of the electronic upgrade. Keep posting updates- I hope you get it figured out! Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | put the points back in. There is about a 50/50 chance it is the pertronix not working. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | new plugs and wires last night and seemed like it ran worse...? Anyways could this be caused by not having a heat plate on my intake manifold? It wasn't doing this before...without one... Gonna check distributor, carb, coil and other ignition problems tonight. Something has got to give.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | An unheated intake manifold could/should cause problems.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Update:
It aint the heat plate... vacuum advance aint working. Gonna pull distributor later today.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Whats usually the issue with this? I got it freed up and pulled... what do i need to look for as to why it wasnt working?
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | How can I test the diaphragm in my vacuum advance with it off?
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Vacuum advance is easy to test. If you are not afraid you can apply suction to the port, the arm should move. Block the port with suction and it should stay. I use my tongue to block the port, and lungs to provide the suction, but then I am old and not afraid I will get any ill effects from the procedure. If it leaks, you can feel the vacuum drop. If it has failed, it won't move the lever. About as simple a test as you can get.
Steve H
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Yup she's done. .. cheapest place to get another one? Ebay was like 55 shipped?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Thanks cheaper than i found. Ordered
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | you will nee to reuse your clamp , don't dispose of it | | |
