| | | Forums66 Topics128,050 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | has anyone ever thought or tryed to use the new plastic or composite decking for the bed
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Dusty, I did some research on this idea a few years back. The only problem with using plastic lumber is that it tends to sag if the space between supports is too large. Using 3/4" lumber (which would match the thickness of the original bedwood) you need supports on a maximum of 16" centers. The space between the bed sill supports is much greater than this. If you could work out some system of additional support on the underside, I think plastic lumber would make a dandy bed.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
