2 members (2-Ton, Gdads51),
107
Mod | | | Forums66 Topics128,093 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I'm in the mist of rebuilding my 1950 chevy. I'm now tackling the Rochester Carb, when I got this truck both choke and throttle cables were detached from carb. I know where the choke cable goes but could someone out there send me a picture as to where the Throttle cable attaches to the carb, thanks | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The vertical cable is the throttle cable, the horizontal one is the choke cable: http://www.pbase.com/dennygraham/image/137737843 This is a 1950, 216 with a Carter W-1 but it's the same cable setup as the Rochester B carb. The throttle wire is routed thru the hole in the vertical throttle link and that is all that is the only retainer for that link. It has a brass stop at the end of the wire that is shown in the picture. DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | wow,that clears it up, it's the brass stop that's missing I'll get one and hook it up thanks | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Denny,
I had the -pleasure?- of working on a 41 Ford that came into our shop. I was quite dismayed when I went to remove the carburetor. Their linkages are TONS better than the GM setup! I've always thought that brass stop on the bare wire was a terrible system. The Ford easy-off rod system seems far superior. At least, until you want to switch to another carb, maybe . . .
Just my thought, anyway. Love my stovebolts, but they didn't ALWAYS get it right . . .
-Michael | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, it does look like a half-arsed setup, but........it's worked for 75 years and I've never heard of one failing. And I asked when I first saw it.
DG
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Nothing wrong with a terrible system that lasts that long (and is so easy to connect and disconnect).
| | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Thanks for the picture it really help to show where the throttle cable mounts. I do have one other question: I can't see how it's set up on the back side of the carb... are there two pin holes in the gas rod linkage (one hole used for the trottle cable inner wire and the other hole used for a cotter pin to keep linkage attached to carb). My truck has one hole only and there was a cotter pin present to keep linkage at carb together. The throttle cable was cut off and not used so I'm not certain. Plus the 216 engine was replaced with a 235 so things have change a bit. If there is only one hole then I assume no cotter pin is needed because the Throttle wire will keep linkage together, right??? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The throttle cable 'IS' the pin that holds the rod on the throttle arm of the carb. I know it sounds real half arsed but again, it is the way they designed it and it is the way they worked for decades without a problem. The throttel wire just slides free in the hole. This shows the wire on the front side of the arm: http://www.pbase.com/dennygraham/image/116251444Your welcome to look thru the album, just hit the previous or next buttons to view the other pictures. Or try this to see them all at once: http://www.pbase.com/dennygraham/1950_fuel__exhaust&page=allDenny Graham Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Denny, thanks that really clears it up, I also notices that I believe you have two fuel filters one at the fuel pump and the other near the carb. Mine is also set that way except I have the plastic bowl near the carb. Why two filters? Wasn't that dangerous to have a fuel filter near the engine manifold? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The screen on the fuel pump will only trap the larger particles, the paper filter right before the carburetor catches the fines. The location is where the original GM accessory filter would have been placed. As far as safety in that location, people didn't analyze and fret over every little detail of life back in those days. The lawyers had yet to take over our lives litigating the smallest discrepancy for their profit. I've never seen a problem with the filter in that location unless you slammed into it with a big old wrench, and common sense should have told you that the engine shouldn't be hot when changing the filter. Very common to these half-century plus old trucks is rust in the fuel tanks. Because of this I've also installed a glass pre-filter a foot or so from the fuel tank outlet, you can see here how much this helps clean the fuel before it reaches the fuel pump: http://www.pbase.com/dennygraham/image/141360697 Denny Graham Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | DJRoy The second "fuel filter" that you saw in Denny's first pictures may actually be the glass bowl fuel pump. It has a strainer in it. > CLICK - Glass bowl fuel pump drawing> CLICK - Glass bowl filter and pump video
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Denny, Once again thanks for the info I really appreciate it and it explains why there's two filters and it makes sense, I will leave both in. I'm amazed at the other inline filter is that actual rust inside the glass? After your pics and info I hooked up my throttle cable now I've got the problem of my accelerator spring pulling back my trottle cable close when I release it (it doesn't stay pulled out at the dash, too much tension). This truck was upgraded from a 216 to a 235 and they attached a spring to the exhaust manifold using a hose clamp which serves as the accelerator return spring for the gas pedal and it's a heavy duty spring and most likely the wrong one. I've done a bit of reading on it and my mechanics book doesn't really say or show much but didn't the spring originally attach itself to the gas pedal linkage at one end and the other to a mounting bracket that was bolted somewhere on the oil pan? Again these might be "no brainer" questions to someone who's seen this set up over and over but for me it's all guess work. I do have a vague idea but if I'm right, do you have any pics on how that's set up?? | | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Thanks for the pics it looks like my "swivel" bracket that bolts to the engine where the gas pedal rod and carb linkage connect has been modified. I also don't have that "clip" where the spring mounts to on the carb rod. I'll see if I can get my hands on a used one or will have to make one up. I do have the bracket that fastens to the oil pan. | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Going to use this Throttle and Choke cable pic to reference my connections at the cables. Thanks
Kevin 1952 235 1/2Ton
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | If you find the brass stop difficult to find, and you happen to enjoy fishing, a split shot sinker crimped to the wire....
Denny, whereas the Ford system looks better, it makes for a more expensive to manufacture and maintain carburetor because of the extra linkage on the off side of the throttle shaft.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
