1 members (JW51), 151 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
I have a 1953 Chevy 3100. The key can be pulled out of the ignition even when in the on position. The problem is that I have burnt out two coils in the last month by accidentally leaving the ignition in the on position. Do I have to replace the tumbler mechanism to fix this or is there and easier way?
Have you tried cutting a new key?
Every original ignition switch and key on my 54 and earlier trucks allowed/allows the key to be removed when the switch was/is "on".
I got used to checking my fuel gauge before I exit the cab (that did not work with my Suburban that had a bad fuel gauge).
I don't know about all of them (being removable) but on the early AD's (47-48) and similar year GM cars it was actually a design setting. My 47-48 AD manuals show it as an operational feature.
https://www.flickr.com/photos/advance-design_parts_co/11597806626/in/set-72157631868452754
https://www.flickr.com/photos/advance-design_parts_co/11597349184/in/set-72157631868452754
This is a "homemade" option on 2 of my 4 transport trucks. The other 2 have key fobs, so I can just keep the fob separate from the key. I love to be able to leave them running & lock the doors when I stop at a rest area to pee!
Bill's Auto Works
Your QUALITY Stovebolt Transporter | Est. 1983
Read more!
The 1957 school bus I rode to high school for 3 years had that type of switch, with the little tab on the bottom of the cylinder. We used to prank the bus driver by one of us distracting him and somebody else swiping the key to the bus. He finally started putting the key in his pocket once the bus was running!
Don't expect the repro tumblers to be any better. I found that out the hard way.
Carl
I saw a old scanned paper article about this some time ago. Its actually a feature made that way so you can leave it running and lock the doors.
But why was it so important to keep the motor running when you stepped out?
Craig
1948 truck Operator's Manual: Bottom of page: Switches - Ignition Switch
You can ask "why", but an answer is not in the book.
possibly to let it run in colder climates and still lock it?
When it's below zero and you want to keep the cab heat up or get the windows defrosted.
When you had a hard start because of the above and you want don't want to do it again until the battery is recharged.
Foreign concepts in California.
I purchased an original ignition from a fellow stovebolter a few years ago.
I never tried to pull the key out, but the key will pull out in the on position. I just cheked.
Recently I purchased a replacement ignition off ebay. I have not used it yet but I checked it, and the key will not pull out in the on position.
so if this is a concern just purchase a new replacement form one of the many vendors.
I had a 64 olds cutlass that the key would pull out while the motor was running
Joe
