| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 37 | How many leafs should I remove from 1949 to soften up the ride a little bit, there are eight now and I removed three and it still seems pretty stiff although I have not driven it yet ( still under construction ) | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | How do you know you need to soften the ride if the rig is still under construction? I would hold and get it on the road first.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | On mine I removed every other one starting with the third leaf from the top. You need to leave the two longest ones for safety. The best thing I did for the ride on my truck was add teflon liner between each leaf, front and back. | | |
