| | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Ready to install my passenger door after installing new door weather stripping and rebuilt hinges. Felt it was too much work welding up a fancy door dolly for a floor jack application, when I have a cherry picker, sitting there, lonely, nothing to do. http://cmaynard.com/Truck/TruckDoorDollyA.JPGhttp://cmaynard.com/Truck/TruckDoorDollyB.JPGhttp://cmaynard.com/Truck/TruckDoorDollyC.JPG
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Nice
I remember damaging my paint fighting by myself
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 |
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Jeez, I wish I had a cherry picker laying around... I could of saved myself from welding up a door dolly for my floor jack!
It looks like you could even open and close the door for testing if the hooks were on the exterior. I like it.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks Craig- That'll be clutch when the time comes!
Brad
Wrench Fetcher, PhD | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | I did have to open up the hooks a little with heat to allow the ends to slide up into the glass channel without having the loops touch the door's surface. CASO, I think the hooks would interfere with the cab if you attempted to close the door while being supported. Maybe not? Maybe so?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It 'appeared' to me it's doable with a little more Hook modification. It sure would speed up the process. ( if time was a factor)
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have the 1 ton HF gantry crane... same principal... yeah.. helps out a TON (pun!) | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Good idea Craig, never would have thought of that, I did mine a few times balancing them on the floor jack, balanced them once on my "big old wife", the floor jack was more cooperative! Expanding on that idea, since I'm planning on working on many more doors for AD trucks, I thought I'd come up with something a bit more permanent. A guy never has enough tools you know: http://www.pbase.com/dennygraham/image/159697608 DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2014 Posts: 104 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 104 | I ended up building a poor man or redneck lifting cradle for my doors on the 52. Just used some leftover lumber; 2x6 and 2x4s along with four pieces of rebar I inserted in holes I drilled in the top 2x6 plate. I covered the rebar with some leftover foam pipe insulation and put a chunk of foam on the top of the 2x6 board on the top. I bolted the contraption to my floor jack. Believe it or not it worked pretty good. It isn't nice like the metal one shown on one of the tech tips but it was cheap and something I could do without a bunch of metalworking equipment. I had also thought about using the cherry picker but the room between my bench and the right door was limited.
Steve
52 6400 50 3600 69 Ford LTD
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well thanks to Craig for striking the spark about using a cherry picker to hang the doors, I made up my version of a dedicated sling for the one fisted bulky-door handling situation. Three bucks worth of 22ga. 12x12 and a few minutes in the shop of chopping and filing and here it is: http://www.pbase.com/dennygraham/image/159879959/large Denny Graham Sandwich, IL
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Thanks for the tip all...........looks as if we all can use/make.... Dan | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | $3 worth of steel, a hundred for the dies to stamp the holes and a few grand for the press to do the stamping. Even a 1 ton arbor press is gonna be over $100. So $3 in steel, $hundreds in tooling. $6 nylon strap sounds like a good deal in comparison. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | From previous post "$3 worth of steel, a hundred for the dies to stamp the holes and a few grand for the press to do the stamping.
$6 nylon strap sounds like a good deal in comparison."
ASSuming one is limited in their creative abilities to the point that making a hole in a $3 piece of steel is only possible by using a press and die, I guess I see your point. Why a drill press, hole saw and a little file/die grinder work or a hand drill and a jig saw with a metal blade or even a plasma torch are not viable options that occur to you as less costly options... I do not know.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ya orta know by now CASO, certain people just have a knack for turning a thread negative or throwing a wrench in the works of every project. I've asked politely for those certain people not to comment to anything that I post but I guess it's fallen on deaf ears. Your quite correct, anyone with the simplest of tools could do the same thing that I did, a hole saw, file, couple of clamps, some scrap iron and a bench for a break and you could make the same tool. Denny Graham Sandwich, IL
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I'm going to make one tonight with tools I dig out of the dumpster.
Out of metal scraps I find on the side of the road.
Just to spite the negative comments. (Which are getting old with incorrect haiku)
I like it a lot Denny & I ESPECIALLY like that you shared the plan/design/drawing picture. As Craig did, and Steve's material list, et cetera...Good stuff, thx all. I may have my disassembled truck back to me in pieces & freshly painted here in the next couple of weeks- never had to deal with being careful with the parts before. All these foam, rubber, & insulation additions to ideas are starting to make sense.
Brad
Wrench Fetcher, PhD | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Brad... are you insinuating I do due do Haiku? Still, I hope that old road sign you find isn't resentful of your using other castaways in new ways and your able to save face (of fresh paint) on your reclaimed parts
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Nah, caso- I was in agreement with you. The three line prose just reminded me of it (haiku); I don't even know if it is three lines or not. I didn't see any easy picking roadside finds on the way home either.
Charlie & his text topic guillotine will be here shortly, lol!
Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | A dairy farmer, part-time preacher always said about people who were obtuse, cantankerous, or otherwise annoying, "We need people like him" as well as, "Bless his heart." I never asked him to elaborate. I figured that he was either employing discrete sarcasm, or that people like that make the rest of us feel better about ourselves, in that WE are not like that. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | 'Bless his heart' Carl, what ever that means.
dg
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Urban Dictionary (even though this is a common Southern or Bible Belt expression):
bless your heart : bless his heart : bless her heart
"A term used prior to ridiculing, insulting the sensibilities of, or pointing out the shortcomings of someone. Used to soften the blow of a statement, and can render nearly any comment, no matter how brash or distasteful, socially acceptable."
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | So great to see good solutions, ALL of them, from the simple to the complex. The concept is called brainstorming, throwing a lot of ideas out there...from the ridiculous to the sublime. What a waste of time to openly state, "This is not for me!" Oh yeah, "Bless ALL our hearts!"
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Or, stated as a haiku:
5 \ 7 > counted as syllables 5 /
bless our helpful hearts it seems like we do mean well most posts are friendly | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now can we finally hang that darn door!!!!!
dg
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Craig, thanks for posting that simple reminder of using what we've got. Keep those good ideas coming...nice shop by the way.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I hung my doors the old fashioned way. I picked them up, slid them on the hinges. But before I did that..... When I was doing the body work and test fitting everything before I painted and I had the doors lined up I drilled a few 1/8" holes through the door and the hinge straps. Then inserted cotter pins and removed the bolts. When I was ready I held the door by hand, pulled the pins and slid the door off the hinges. When I installed them I attached a thick blanket to the front of the door jamb to keep the door from sliding into it, picked the door up, slid it on the hinges and put the cotter pins back in. It automatically lines the door back up to where I had originally fit it. Then I put the bolts in.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And hope the guy that adjusted the doors the time before you got it right.
dg
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It's So BIG Denny! I couldn't help but laugh when I saw it man. I think we need to come up with something more between your engine hoist and a IV stand. Closer to the IV stand... that fits in the garage...
(just messing with ya)
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You do it your way, I'll do it mine. I've been accused of looking for the easy way out many times, rather than fumbling around and taking the hard way of doing a job. Depends on where you stand I suppose. One can look at it a couple different ways, as either I'm lazy or I'm wise. The easy way always seems the wise way to approach a problem in my mind. Besides, I can control my engine hoist easier than I can control my "big old wife", that third hand make the job of adjusting the door a pleasure instead of a pain. Sorry if you don't have room for an engine hoist, maybe you need a bigger garage if you'r gonna work on your own Stovebolt?
dg
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | But Denny.... It's NOT IN the garage  I still like your hanger piece a lot  and I get using the tools you have on hand, but... Its So BIG!  I guess I just want to see a hanging set up like your's thats as small a footprint like my floor jack  I guess it's off to the medical supply store for a couple IV bag stands...
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Bottom line is,use the tools you have available. Denny is showing his way,he's fortunate to have some really nice equipment and tools. Anybody can set a door with some patience.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | But its so fun messing with Denny! Actually, his solution is pretty decent. You could use two smaller ones too. What I like about this site is, we can mess with our friends here without them getting all BENT about it, AND we learn new things along the way! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Riiight. been wrestling with those doors by hand or with a jack or with my wife or daughter before and when I saw Craig's idea about using your cherry picker I thought he'd stumbled on the right solution, and it was. Made a super easy one man job of this task, doors close nice and easy now and line up and it only took a few minutes. Gotta go, can't play any more, Mom's callin' me in for supper. dg
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yep. That was THE solution for sure. | | |
