8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18966 04/13/2004 1:58 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I'm ready to mount radiator core support to the front cross member. The assembly manual shows several "shims" above and below the crossmember. The kit I ordered from Jim CArter has only two square rubber pads. My question is do these go on top of or underneath the crossmember. Also what thickness shims and how many? I suppose this effects the fit of the hood and fenders. Any comments from someone who has been there would be appreciated. Thanks | | |
#18967 04/13/2004 6:08 PM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | Just using a little logic, the rubber pads would have to be cushions and most radiator supports I have seen over the last fifty or more years, had the pads on top of the cross member or frame to cushion the support so I would say that they go between the support and frame.
Truck Tinker | | |
#18968 04/13/2004 6:23 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You're right about the shims effecting the hood and fenders. You will have to adjust things when you put it all together. Iirc, the shims in mine were about 1/16" thick. They can go on either side of the pad, you just need the pad in there somewhere. I think mine had 3 shims, but the fit of these old trucks varies a lot. Nothing precise about them.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | 3 shims @ 1/16 + 1 pad @ 1/4 = 7/16 of "height". Gives me a good idea of how much I may need to elevate my radiator! Trial and error but it's someplace to start from. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I was fitting the front clip, I removed the bolts that go through the shims. I then used the support rods that run from the firewall to the fenders to line up the fenders and the hood. I then made a rubber pad to fit with the shims. | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | This really is a challenge with all the variables involved! Right now I'm trying a height of 11/16 with the shims under the radiator support. Don't have enough gap between the cowl and rear of the hood now. Time for another "golden nectar". | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If the core support has to be raise to much to get the hood to fit the cowl correctly, you might look at the rear of the cab to see where it's setting. By shimming the rear cab mounts or reducing the front mount thickness you can bring the core support down to where it should be, that is with about a 1/4" rubber shim and one or two thin metal shims.
dg
Denny G Sandwich, IL
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Rwise, I realize this is an old link but the following still applies. I like to know who I am talking with, what is your name? Also we can offer better answers if you tell us what year truck you are working on. Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | .250 worked perfect on my 47. Consistent with what I took out before rebuild. As Denny said, cab positioning falls into play but cab also must be parallel with running boards (gap). So not much movement is preferred.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
