5 members (68ironhead, Maybellene, Southerntruck, GMCJammer51, 1 invisible), 62 guests, and 5 robots.
Topics128,064
Posts1,055,861
Members48,428
#1095793 04/06/2015 1:06 PM
is there a list of the cam casting numbers somewhere.. and a way to find the specs on my original 261 cam.. i was also wondering if i could run a set of chevy V8 solid lifters in my 261
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
Not sure about the casting number source, but the same cam core might have been used for different grinds, so a casting number might not help with timing and lift numbers. Definitely "no" on the V8 lifters- - - -the stovebolt lifter is larger diameter and taller than the V8.
It only takes a little bit of setup with a degree wheel and a dial indicator to determine exactly what you have, in or out of the engine, no need to engage in a lot of guesswork about a cam!
Just remember if you're using a lathe or a set of V blocks to check the cam before installation, that one degree of cam rotation equals two crankshaft degrees.
