6 members (Barney1951, treegrower, TUTS 59, Gray_Ghost, cmayna, UtahYork), 85 guests, and 0 robots.
Topics128,067
Posts1,055,877
Members48,428
#1095400 04/04/2015 3:12 AM
I have a 235 55-57 chevy and the harmonic balancer pulley itself will not keep paint on it. Have any of you ever seen a galvanized pulley on these factory.
Nope.
My Blog
Always bare steel. Scuff with sandpaper, clean with brake cleaner and paint.
Fred
52 3600
69 C-10
That's what I did but only thing different is in the beginning I soaked it in mollasis and water to remove rust on the outer ring. Washed it off thensandblast brake cleaner and dried then sprayed. Almost all lifted the next morning, and I can scrape it off by fingernail on just the pulley. Guess I'll try it one more time.
Try some self-etching primer. Rustoleum makes some that I have have good results with.
Carl
