8 members (TexasJim50, Otto Skorzeny, Greg_H, GusG, Lonnie, Nick in Manitou, J Lucas, moparguy),
102
Mod | | | Forums66 Topics128,089 Posts1,056,428 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hi Folks, Just finished re adjusting the valves and re gapping my spark plugs. Started my truck and -WOW-the idle Speed is up by 200 RPM! Valves were too tight and the plug gap was too tight. Opened the plug gap to .040 (pertronix ignition) and my valves to .008 I and .018 EX - cold. Haven't driven it yet. Weather is really bad. Should be OK next week. Anybody able to explain the jump in idle speed? Thanks and Happay Easter | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hi Folks, Nobody has replied to this post and I am thinking that maybe I didn't pose my question correctly. It's obvious that with valves too tight and plugs gapped incorrectly, somethiong had to change for the better. I am wondering if anyone has a technical explanation as to how or why idle Speed jumped 200 RPM. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sepp, all other things being equal the engine may be operating more efficiently and making more power on the available fuel after the adjustments you made. Adjusting the idle R.P.M. is part of a normal tuneup, hope that helps. | | |
