1 members (WICruiser),
209
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | I have a 1950 Chev 1/2 shortbox. I heard the old Nova front clips were an easy mod. I even heard someone say the sub frame slid directly in between the original frame. This almost sounds to easy that is why I need to ask before a guy takes the plunge. Has anyone done this? Have pics or a video? Thanks Darcy | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Reference the sticky at the top of this page. All the info on this project that you could ever want and then some. Good luck.
| | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | I Checked the sticky out and no mention of welding in a Nova sub frame. I`d love to see a build done with one. I heard the almost slide right between the rails of the 47-53`s. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You are correct, no one mentions the Nova swap. I had a frame once that had the Nova conversion on it and it looked the same as my Camero conversion on the '47 3100 frame I have now. If you can use a tape measure and a welder you can do it. Good luck with your project.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might want to check with " BC52 " on this forum. He has a 52 with Nova clip. Fellows name is Boyd. He is on the B.C. Bolters site. | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Darcy,
I put a 69 Nova clip on my 49 suburban several years ago and have had no issues . Not to difficult just need to take correct measurements to get wheelbase correct and graft the subframe to the frame. I bought clip for $ 200 and spent $2-250 to rebuild a s in new condition, plus $100 for w certified welder to burn it in once I had it tacked together. I'll try to find some pics if you send me a PM. Just need to be a good welder or find one to do the job
Sid
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | I've mated a '79 Firebird front subframe to my '54 halfton. It was a near-perfect fit. Any Firebird from '71 thru '80 should work the same. --Al | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Anyone know their Novas? I was told my clip was around 1974. It has the shock absorber bumper mounts which makes me believe its newer. Bushing kits and rotors, etc are not the same between the earlier ones and mid 70`s. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | 68-72 are rear steer 73 and later are front steer | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Mine is rear steer. I have been told by the builder that it is a 74.I can't answer about bumper mounts.If there were any,they are gone.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I hate clipped frames from an engineering point of view. you will need to fish plate the joints.
I much prefer an IFS kit under the stock frame.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The joint is way stronger than any other part of the frame so one needs to taper the boxing plate or make a parabola shaped cut in the end to give a transition area from super rigid (the joint) to wet spaghetti (the "C" channel frame). If cut square and used hard cracks can develop where flex meets rigid.
Evan
