| | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | Hi all, need some help!
I'm working on my 216 and can't get spark. I've removed the points and installed a Pertronix Ignitor with 40,000 coil. New wires, plugs, cap, and rotor. I'm pretty sure the timing order is right and even tried rotating all the plugs to every one to try it out but no luck. I don't have someone to help do the finger on #1 plug to find TDC, so I thought the trying every possible combination would yield something, but nope. The dizzy was never removed, so that shouldn't be the problem.
I ran a jumper wire from the battery to the ignitor module as I didn't know if the trucks electrical is ok as it was upgraded to a 12V. No luck.
I hooked up a timing light to see if it would flash when the engine is trying to turn over, but there's nothing. I'm at a loss for what it can be.
The only thing that could be possible that I know of is the engine ground, but I would think that would be fine as the other electrical works.
Any thoughts/help would be appreciated. | | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | Put the points and condenser back in it and see if you get a spark. If you do, send the Pertronix back where it came from! Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Might the new coil be wired backwards?
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | The old points and condenser were shot. Which is why I got the Pertronix.
The coil is wired with negative to the negative on Pertronix and also negative to a ground on the body. Positive in the coil isn't connectd as the Pertronix manual said to unplug the power to Pertronix from coil and run a jumper to the battery which I did but still didn't work. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Which wiring arrangement in these instructions do you have? Both leads on the coil have to be connected to something. If you have the Pertronix 12 coil, I think the middle diagram (Figure 2) should be used? Here is another Flamethrower wiring illustration. | | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | I have #3, but since it wasn't working I followed the FAQ to remove the hot from the ignitor to the ignition switch side of the ballast and use a jumper to the battery. Should I ditch the ballast? That's one thing I didn't replace. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have the Flamethrower coil? It does not need a ballast resistor.
If you have another coil, and it does not have an internal resistor, you will need a ballast resistor.
Please post a link to the FAQ you refer to.
You must run a lead through the coil, and then run a lead from the coil to the Pertronix unit.
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | Yes it's the flamethrower coil. I'll bypass the ballast and give it a shot tomorrow. Thanks! The FAQ is on the first link you posted. It's the second question. | | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | So I couldn't wait and went out to try it. Removed the ballast and connected the ignition wire directly to the coil. Ran the ignitor directly to the coil as the diagram showed and no luck. Then tried to bypass ignition switch by connecting directly from the battery to the coil and nothing.
Guess back to the drawing board. I hate electrical gremlins!! It would probably be easier to just get a whole new wiring kit than trace back whatever was previously done. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Your burn up your coil if you bypass you ignition
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | It was only "on" for 5-10 seconds tops | | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | I'm also running the foot starter... If that has any impact, although I heard it wouldn't. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You should be ok
I don't understand the additional ground from the coil?
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | I was just trying that to see if it was a ground issue, but didn't help so I took that off. I'm at a total loss on this and past my point of frustration. LOL.
I have a SBC on my '39 with HEI and MSD and it was 1,000 times easier. LOL. I wanted to keep my '49 original for the most part, but now I'm second guessing that. LOL | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you have a meter?
When you turn the key on do you get voltage at the coil?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you have the Flamethrower coil? It does not need a ballast resistor.
You must run a lead through the coil, and then run a lead from the coil to the Pertronix unit. | | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | I'm using figure 2 in this link now. link http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.pertronix.com%2Fsupport%2Fmanuals%2Fpdf%2Fignitor12vneg.pdf&ei=AdUdVaGcIdC1sAToz4CwDA&usg=AFQjCNH_kEbUdAOmrSd-ztFD8kBHs5512w&bvm=bv.89947451,d.cWc
| | | | | Joined: Sep 2011 Posts: 15 New Guy | | New Guy Joined: Sep 2011 Posts: 15 | I have a meter so I will check on power to the coil. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The coil is wired with negative to the negative on Pertronix and also negative to a ground on the body. If I am reading this correctly the wire to ground on the body is your problem. That is the same thing as keeping the points closed all the time. The Pertronix needs to be the intermittent ground for the coil to get spark.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | that is just what i was thinking.. if i read the post right | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I'm using figure 2 in this link now. linkfigure 2 should work red and black wire to the coil ignition wire to the + of coil if your distributor was never removed you should still be in time. what model number ignitor did you get? there is a 6v and 12 volt version | | |
