8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe),
338
Mod | | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Was wondering how people ran their wires to dome light without it being blatantly visible that there's a wire running up the cab. Do people go along the roof area or just up the back of the seat? Thanks,
Jonny
1950 Chevy 3600 w/ 54 235 motor
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1950 cab?
The wire runs up/behind the driver-side door post, and then behind/above the roof cardboard to the rear of the cab, and then over to the dome light.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ..Yeah... you can see the wire on the top portion of the above pic. the clips and wire are above the headliner should be about 5 clips holding the wire in place | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Blow a piece of string down the A pillar with compressed air. Tie it to the wire and pull it up. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If the blown string does not work, try fishing a copper wire from the top downwards. Connect the lead to the copper wire and pull up.
It is much harder to fish the wire from below the dash upwards.
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Old speedometer cable (not the housing) works good for fishing the wires through also.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Wonderful, thank you gentlemen.
Dads50 - it brought me to an album, was there a specific picture I was supposed to look at?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | you must be on a mobile device here is the pic but It may not be much help if your headliner is installed it will show how the wire was found on my 50 held with clips ...link... | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | you must be on a mobile device here is the pic but It may not be much help if your headliner is installed it will show how the wire was found on my 50 held with clips ...link...Perfect, thank you. I switched to a desktop. Thanks again!
