Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Hotrod Lincoln, Dennys28, Wayne67vert, MickeyP, Otto Skorzeny, 2 invisible), 176 guests, and 6 robots.
Topics128,284
Posts1,058,532
Members48,490
dx3
Offline
Was wondering how people ran their wires to dome light without it being blatantly visible that there's a wire running up the cab. Do people go along the roof area or just up the back of the seat? Thanks,
Jonny
1950 Chevy 3600 w/ 54 235 motor
1950 cab?
The wire runs up/behind the driver-side door post, and then behind/above the roof cardboard to the rear of the cab, and then over to the dome light.
..Yeah...
you can see the wire on the top portion of the above pic.
the clips and wire are above the headliner
should be about 5 clips holding the wire in place
Blow a piece of string down the A pillar with compressed air. Tie it to the wire and pull it up.
If the blown string does not work, try fishing a copper wire from the top downwards. Connect the lead to the copper wire and pull up.
It is much harder to fish the wire from below the dash upwards.
Old speedometer cable (not the housing) works good for fishing the wires through also.
Brian
1955.2 3100 Truck
dx3
Offline
Wonderful, thank you gentlemen.
Dads50 - it brought me to an album, was there a specific picture I was supposed to look at?
you must be on a mobile device
here is the pic
but It may not be much help if your headliner is installed
it will show how the wire was found on my 50
held with clips
...link...
dx3
Offline
here is the pic
held with clips
...link...
Perfect, thank you. I switched to a desktop. Thanks again!
