4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
I have a chevy 12 bolt on my 55.2 (that came off a '78 blazer). I'm going to pull the rear differential and put in new fluid (I don't think it's been done since ...1978). I know you need to put additive in the oil if it's a posi rear end, but I don't know how to tell. There is no tag on the rear end. I did the test of spinning one wheel, and the other wheel spins the opposite way, but some of the reading I've done says that is NOT 100% accurate. Any one have tips on how to tell if the rear end is posi or not?
1955 GMC 100 Series 2
H Online: Content
Jack up one wheel, and GENTLY accelerate the throttle with the transmission in gear. If the vehicle tries to pull ahead you've got a posi. Don't go much above idle, just enough to try to spin the jacked-up wheel. An "open" differential will allow the lifted wheel to spin freely.
Easy to tell w/ cover off. In center of diff you will see side gears (splined to axles), diff. pinion gears (spiders) w/ pin going thru them & the case. This is an open differential. A posi, limited slip or locker will either have a spring pack, locking latch, ect between side gears in center of diff.
BC
1960 C60 pasture art
