7 members (Otto Skorzeny, Phak1, TUTS 59, Hotrod Lincoln, Gray_Ghost, Crimson48, 1 invisible),
134
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | My 50 chevy 3100 short bed has the original slide in/out type spare tire holder under the bed. I want to use it but I lost the pin. I want to manufacture a pin and I was hoping someone could tell me the diameter and length of the pin? | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | I've got a '49 with the spare tire under the bed. I have no idea how original it is, but can take a picture and tell you what I have if nobody else responds.
Greg Brown
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Sorry but what exactly is "the pin"?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | Before I climb under the truck to get your dimensions, I thought I should ensure we're talking about the same spare tire holder. As I reread your original question saying "slide in/out" type I wasn't convinced I have what you're referring to. Here's a couple pictures. http://1drv.ms/1HknhRfIs this the same one you're referring to? If so, which pin are you referring to?
Greg Brown
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Sorry but what exactly is "the pin"? ...pin... Couldn't you just measure the receiver rail? | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | DADS50 - that is what I call the pin on my carrier. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | OK, it's the small rod or pin on the brace that the spare is bolted to, which slides up and down the fixed brace. If so, I can measure mine but not 100% certain that all spare tire braces were made the same. I think mine is a repro so all bets are off.
Thus I agree with DADS50 to just measure the ID and width of the fixed brace to see what is the largest diameter pin that could be used.
| | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | Thanks guys, I am referring to the pin that slides on the angled portion of the spare tire rack under the bed. I can figure it out and make my measurements from what I have. I was thinking it may be in a book someone has but those details may not exist any place. Thanks you for all your previous help with my project! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, its a GIGANTIC cotter pin. Ive never seen a cotter pin that big. Good luck on your search. Maybe McMaster-Carr has them? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | McMaster-Carr doesnt seem to have any that long, nor Grainger. Check with Bowtie Bits in Wichita, KS. Any vendor that sells used parts may have them. You can always get some 3/16" steel rod from the local hardware store, drill a hole at each end for a cotter hairpin. It would be a more elegant solution than stock. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | 3/16? 5 inches long? If it is 1/4" and Gus is wrong, even after he deleted his post, I don't see it at Grainger. Can you give us the exact link? I would order a few of them. Mine are always in really poor condition. Thanks! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It's the cotter pin Denny. I can't seem to locate manufacturers who make them that big anymore. Perhaps that is why you have instruction on how to make them? | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Thats perfect Ken! McMaster-Carr didn't have them, Grainger, and Fastenal either. Thanks for doing the research! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now when you figure out how to order from Imperial and you get your package of 25, you can supply the group with monster cotter pins Deve. But count me out, next time I need one, I'm just gonna throw a foot of 1/4" round stock up in the mill and take a couple of passes, then make a bend around a 3/16 bolt and pinch it in the vice. A lot faster for me than waiting for my package of 25 to arrive. Plating? Nah, who needs it, the original one on mine wasn't plated to begin with. http://www.pbase.com/dennygraham/image/152675445 dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Never thought a spare tire rack would get so much attention. LOL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh you haven't looked thru the archives Craig. There has been tons of discussion about the spare tire carriers. There is a certain group of people that care very much about 'restoration' of these old trucks on the 'bolt. Then there are those people who's only concern is to keep them them running and couldn't care less about originality.
dg
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Agreed 100% Besides, I was only joking around.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I know you're no a greenie here Craig, but a newbie might not know that some of us are into those tiny details. And those tiny details are what keeps the hobby interesting. I mean....a cotter pin....three pages of discussion??? dg
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Well lets shoot for 4 pages. I am still trying to figure out what the purpose is for that cotter pin/slight swivel arrangement. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | My guess would be that they needed it to slide to accommodate different size tires Carl. The cotter pin was simply a cheap inexpensive off the shelf way of retaining it. Could very easily been a long clevis pin but then you would still need a second part....a cotter pin.
Denny Graham Sandwich, IL
| | | | | Joined: Oct 2008 Posts: 48 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 48 | Are there any other more modern trucks that have a similar rack that is compatible with our Stovebolts? This is a hidden, utilitarian item that I am not very "picky" about in a restoration to near-stock condition, so I may cut a corner here and look for something more findable at the local boneyard... if possible. Any suggestions? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Are there any other more modern trucks that have a similar rack that is compatible with our Stovebolts? This is a hidden, utilitarian item that I am not very "picky" about in a restoration to near-stock condition, so I may cut a corner here and look for something more findable at the local boneyard... if possible. Any suggestions? Not sure what year truck you have but take a look at this https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1095900#Post1095900I also read on another site a guy used a underbed carrier off a 1979 ford pickup | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | They sell aftermarket underbed spare tire carrier systems for the AD. At least Jim Carter was doing it for awhile, not sure if he still offers them. Going that route, you wouldn't have alot of fabrication to do. In truth, it wouldnt be that hard to design an underbed spare tire carrier. Rather than all of that sliding crap, you could just put a hinge on the back side. If that isnt your thing, a drawer slide. If I wasnt so busy already, I could draw something up.. so if I can do it, anyone can. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I agree. Even an extra 1" length to spread apart would not hurt anything except at a Concours show. Harold
Harold Is a restoration ever finished? | | |
