0 members (),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I need to repair the leak from the input shaft on the rear differential. The parts books don't list a pinion seal for a 1954, but they do for the later years, example - 1972 C20 with Eaton HO52. Shows an SKF 25970 seal and National 5M89 Felt seal. The Shop Manual describes and oil seal and packing, but it isn't too clear to me. What do I need to know to get this right the first time? Help, please.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Dusty53 your SKF seal number is correct also the same as National p/n 411330N. As far as the re & re, remove the driveshaft hold the pinion yoke with a large pipe wrench braced against the ground or frame or something solid, remove the pinion nut and remove the yoke. You can probably pry the old seal out and replace it with the new one. Inspect the yoke for a groove in the seal surface, if you find a groove you should install a Speedi-Sleeve to give your seal the best chance of sealing and surviving for any length of time. If you do need a sleeve take your yoke into your Friendly Local Auto Parts Store (F.L.A.P.S.) so that they can measure it and order/supply the correct sleeve. When all your pieces are ready for assembly put everything back together and torque the pinion nut to the correct torque, use the pipe wrench again to hold the yoke, Do not count on the tire/axle to hold the yoke, ring and or pinion teeth have been known to break when the yoke is not held by some kind of device, this is especially true if an impact wrench is used, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | From that same Rockauto.com page:
NATIONAL Part # 99259 Redi-Sleeve Rear Outer; GMC H072 (Only 1 Remaining) $25.99
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Thank you Tim and thank you 3B , that covers the seal perfectly, what about the "packing" is it replaced by the felt ? Will I need the Felt Seal that is also shown in the parts list for this online ?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Dusty53, I believe the "packing" was the felt, and I believe the felt was eventually discontinued as well. However you already posted the part number so you could purchase one and install it if you like. I am not sure about the number that tclederman posted for the sleeve for the pinion yoke, in the part description it says "Rear Outer; GMC HO72", not pinion yoke. I'll see if I can confirm the sleeve part number, hope that helps. Okay I have confirmed the sleeve part number is correct for the pinion yoke SKF 99259 SKF p/n for the felt is 528 (it was discontinued in 1960)
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | 3B , you've been a great help. The "felt" part number was described as 'Felt, pinion", the description lists a shaft size of 2.500", and outer diameter of 3.438" and a width of .313". I noticed the OD is smaller than the "seal" OD which is 3.486" but assumed that it gets compressed and probably acts as a means to keep out dirt, etc.... does this sound right to you? Last question, I hope.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need to remove the 5 bolts & take the flange off to remove the seal. It comes out the back of the flange. There is a special gasket that goes behind it. You can use a heavy bead of RTV. There is no crush sleeves on this rear end. You can tighten the pinion nut securely & tighten it line up the cotter pin hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Wrenchbender, thank you for the directions, its appreciated. I think I just might pull this one off without breaking it! Thanks to all who've responded.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jan 2009 Posts: 25 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 25 | this is old news but I have a new one on a 50 chevy 3600 pinion seal
u joint yoke fits on a splined shaft ,,, where does the seal go ? | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | this is old news but I have a new one on a 50 chevy 3600 pinion seal
u joint yoke fits on a splined shaft ,,, where does the seal go ? The seal runs on the outer surface of the u-joint yoke where it slides onto the splined shaft.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2015 Posts: 7 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 7 | I have a '54 3600 that needs to have this done. I am not very mechanical however my local mechanic is hesitant to perform this as he feels he would need to approach the pinion seal from inside and remove the differential gears. For those of you that have replaced this seal does the advice from "3B" up above in the thread hold true? Can it be done externally?
Any step-by-step advice would be great. I have the seal and will probably need a sleeve. any help would be appreciated.
Thank you
MTCTH
| | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Your mechanic is wrong. the pinion doesn't have to come out. Just unbolt the yoke and the retainer. Actually a pretty straight-forward job. Here's a blowup of the differential
MTCTH
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Hey MTCTH , based on my own experience I recommend you consider purchasing a "Chevrolet Truck Shop Manual 1954 Models" . There are reproductions available from most of the parts suppliers and sometimes originals are found on Ebay. It'll pay for itself very quickly.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Sep 2009 Posts: 6,056 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,056 | In the mean time, while you possibly seek a hard print copy of a 1954 Chevy Truck Shop Manual as Dusty53 suggests, you can access an electronic copy HERE courtesy of the Chevy Old Car Manual Project!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
