| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I've made some progress on my 4t6 bed. I used poplar wood from a local sawmill that I cut to size and dado the edges. I used a green latex paint thinned down to like water and used as a stain then 3 coats sanding sealer. I sanded between coats with 220 and then placed 3 coats of Spar poly again sanding with 220. I want to get it mounted with holes drilled, offset washers in place and fitted correctly then I'll remove sand and reapply varnish. =138319804&filters[recent]=1&sort=1&o=0]Some pictures here. Thanks to all here for your daily input and advice. Have fun and good luck. Dan | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | You chose a very nice wood that compliments your truck color. Poplar or aspen is an underrated hardwood and it is often overlooked for its woodworking qualities and ability to take a finish.
I think the bed looks great and your truck looks fantastic! thanks for sharing.
Nice work!
Tom | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I never would have thought to recommend poplar to anyone. But after seeing your pics with it in a white truck, I have to say that it looks awesome! Carl
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Thanks all! Now that the weather is more cooperative you'd think I could work more on it but that's just the opposite....always something else to do. Dan | | |
