0 members (), 80 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#1095003 04/01/2015 6:06 PM
I've made some progress on my 4t6 bed. I used poplar wood from a local sawmill that I cut to size and dado the edges. I used a green latex paint thinned down to like water and used as a stain then 3 coats sanding sealer. I sanded between coats with 220 and then placed 3 coats of Spar poly again sanding with 220. I want to get it mounted with holes drilled, offset washers in place and fitted correctly then I'll remove sand and reapply varnish. =138319804&filters[recent]=1&sort=1&o=0]Some pictures here. Thanks to all here for your daily input and advice. Have fun and good luck.
Dan
Chev4t6 #1095010 04/01/2015 6:17 PM
You chose a very nice wood that compliments your truck color. Poplar or aspen is an underrated hardwood and it is often overlooked for its woodworking qualities and ability to take a finish.
I think the bed looks great and your truck looks fantastic! thanks for sharing.
Nice work!
Tom
1946 GMC Project
"Back-in-the-day Restore"
Chev4t6 #1095136 04/02/2015 2:41 PM
Very nice!
Drew
Chev4t6 #1095166 04/02/2015 6:02 PM
Yes! Very nice.
Chev4t6 #1104622 05/25/2015 1:59 AM
I never would have thought to recommend poplar to anyone. But after seeing your pics with it in a white truck, I have to say that it looks awesome!
Carl
52Carl #1104912 05/26/2015 3:23 PM
Thanks all! Now that the weather is more cooperative you'd think I could work more on it but that's just the opposite....always something else to do.
Dan
