1 members (baldeagle), 65 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#10949 04/11/2005 4:33 PM
Junior Member
Junior Member
Guys, I've been having problems with my Rochester carb on my 60 model 235. It used to work fine but now the float sticks and it floods off and on. I have rebuilt it once, but I think it's just worn out. I'm considering replacing it with one of the Holly Weber setups. My question is if this is a good idea, or should I just order a new Rochester. I use this truck offroad only at the deer lease. I seldom get above 20 mph. I just need it to run smooth. I have no doubt the Holly Weber setup is better, I just question if I need it in my situation? Any opinions?
#10950 04/11/2005 5:07 PM
The Holley/Weber 5200 is a very good carb, and Langdon sells them cheaper than you'll find a rebuilt Monojet or B.
Boo
We don't need no stinking V-8s!!
#10951 04/11/2005 5:45 PM
Junior Member
Junior Member
Boo, I can get a rebuilt B for $88 from O'Reillys. It would cost me around $145 to get the Holly with adabter,linkage, and air clearner.
#10952 04/11/2005 10:46 PM
Riding in the Passing Lane
Put a kit in the Roch. It,s about as simple a carb as is out there. Make shure there is an inline filter going into the carb. Most flooding is caused by foriegn particle in the needle & seat. Shake the float when you get it off to make shure it hasn,t got gas in it. smile
1972 Chevy c10 Cheyenne Super
#10953 04/11/2005 10:56 PM
The Rochester should work fine in your situation. I don't know what you have for a fuel filter, but it sounds like dirt in the carb. If you put a kit in it, check the throttle shaft for wear. If it moves more than .007 laterally, the shaft will need a bushing.
I'm not too fond of the rebuilds being sold nowadays, most have been done by the same people that do the starving artist paintings.
Fred
52 3600
69 C-10
