5 members (Oswald, Otto Skorzeny, baldeagle, Hotrod Lincoln, 2-Ton), 119 guests, and 3 robots.
Topics128,184
Posts1,057,195
Members48,465
my 59 napco carryall needs another roof ! i was told it unbolts along the sides and has to be cut in front windshield posts to remove ? what about the back corners next to rear doors ?? need any cutting there ? anybody confirm this ?? what do you think it weighs ? how many to lift it off ?? thanks mike think i found one/but just in case still looking for one ! a panel truck is the same !?
Currently cruising
in the
Passing Lane
Sir Searchalot
Sir Searchalot
Panel truck is the same. All needs cut. Don't know of any bolts. The sides are "gas or arc" welded to top with probable spot welds at "A" pillar and bulkheads. Where is problem? Drip rails? windshield surround? why whole roof? Red58, et al, can confirm or suggest options. Is this a rust repair or accident repair? Sounds like you have already made your decision but try to see if there is a way to repair just sections with your donor.
The weight will be approx. 90-110 lbs., two guys can lift.
I replaced the entire cowl with door and windshield frames from a donor pick up. But it is a 37. Had the top off at the same time. Cut top at b pillars drilled out spot welds across wind shield and top of doors. The rest is bolted. I don't know that yours is the same
1937 Chevy 1/2 ton panel
I sent you a PM.
First attempt on this site, so I hope it went correctly.
1 Offline
Did the same on my 51. I guess the technique remains the same? If so you can see in my gallery pics. Good luck
