2 members (hardshell, Nick in Manitou), 74 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#1094878 03/31/2015 11:18 PM
Looking online in the past i have seen that lots of people who are not running cab heaters just block off the heater line ports on the housings. Is that not an issue with coolant circulation during a cold start?
I had my top housing one blocked off on the side port but Im running a intake heated system with a ported spacer so I still get circulation thru the block when the thermostat is closed. I was wondering because yesterday I was installing a new heater system in my truck and it just crossed my mind.
All water pumps starting in about 1950 have a bypass hole in the pump that allows water to circulate from the pump back through a passage in the block and up to the head while the thermostat is closed.
In thinking about it, the water actually would flow the other way, from the head..
My Blog
that answers my question. thanks
