8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | which dual master cyl. is better for drum-drum brakes i am working on 1954 1/2 ton chevy and what to do a dual master for safety. also is the cpp bracket a good choice to mount the master cyl? | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | i just talked to cpp they say i need bracket, master cyl, and two 10 lbs. pressure valves to do the job anyone use their products? let me know how they worked? | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I ordered my MC and bracket from classicparts. When I got them, they were actually from CPP. MC: Dorman M89160 Bracket: worked perfectly with no modification and I got two 10# pressure valves from Summit | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | My son and I just finished installing the dual MC from classicparts. Didn't have an issue with the bracket.
I was unaware of the need for 10# pressure valves. Can you provide more info on this? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy The Hill Boys, if the master cylinder used was designed for a disc/disc, or disc/drum system but actually being used on a drum/drum system, then the circuits that were intended for disc brakes would need a 10 p.s.i. residual pressure valve installed. Residual pressure valves maintain a pressure in the lines of the drum brakes which helps to keep the piston cups against the wheel cylinder walls and that pressure also helps counteract the action of the brake shoe return springs, without the residual pressure valves the brake shoe return spring will force the wheel cylinder pistons together in the wheel cylinder, this action will cause the brake pedal to feel low on the initial brake application and then feel correct on subsequent applications. This action will occur every time the vehicle is allowed to sit unused for a time, the other issue that occurs without residual valves is air can be drawn past the wheel cylinder cups which can contaminate an alcohol based brake fluid with moisture causing rust to occur in the system and a possible spongy feeling brake pedal, hope that helps. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I agree with most of what 3B says about the need for the residual pressure valves, except for the fact that they're only needed with a MC on drum brakes that was mean for a disc/drum, disc/disc circuit. Regardless of what the MC was made for (dr/dr, di/dr, etc), IF the MC is below the floor, or below the wheel cylinders, it needs to have 10# residual pressure valves. If its below the wheel cylinders, then theres a chance that fluid will drain away from the wheel cylinders... resulting in what 3B described above. In my opinion its a necessary safety precaution
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thanks for the info gentlemen. Looks like I'm not done with the brakes after all. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for the info gentlemen. Looks like I'm not done with the brakes after all. Are you drum/drum. ? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It seems to me that the factory never put out a system that didn't include residual valves, no matter where the MC was. The theory that it is OK with no residual valves if the MC is above the wheel cylinders, doesn't make any sense. If that explanation was correct, the truck couldn't be parked on a steep hill if it caused the MC to be below a wheel cylinder. Those valves are there to retain a positive pressure in the system and prevent air infiltration. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMJager and guys, my comments on residual valves were aimed at the question being asked, I did not intend them to be a tutorial on all the possible permutations of brake systems. I never said that residual valves were only required for drum brake systems. As GMJager said if the master cylinder is mounted closer to the ground than the wheel cylinders or brake calipers then resisdual valves should be used to prevent fluid drain back to the master cylinder, 10 p.s.i. valves for drum brakes and 2 p.s.i. valves for disc brakes. I always try to answer the question being asked with only the information needed to answer that question, so as not to confuse the person asking the original question. Perhaps a Tech Tip on brakes would be a good idea. Hope that clarifies. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I should comment on my statement above. The idea of not using the residual valves is being pushed by the suppliers of these parts and I find that quite disturbing. I respect the opinions and advice of our members here. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMTK and guys, most of the conversion kits I have seen advertised use master cylinders designed for Corvettes, Corvettes were full disc brake cars. Drum brakes need residual valves (10 p.s.i.) to function correctly. I assume that the aftermarket suppliers decided to stock/sell only disc brake master cylinders and also sell the residual valves to those installing their kits on drum/drum or disc/drum equipped vehicles. The problems arise when the purchaser of the kit doesn't realize that the residual valves are required for their particular installation and the person taking the order doesn't know what's required, or thinks to ask what type of braking system this kit is being installed on. Other than the non stock bracket required to mount the dual master cylinder in place of the single master cylinder, the parts to convert should be available through your Friendly Local Auto Parts Store (F.L.A.P.S.). If you have a good F.L.A.P.S. you should be able to come up with a system that will be adequate for your application and not require separate residual valves because those valves will be built into the correctly spec'd master cylinder, hope that helps. | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks 3B for the clarification, makes sense now. Seems the local stores are also cheaper than ordering online.
1955 GMC 100 Series 2
| | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | That's the one we bought/installed. Nothing was supplied indicating application or if residual valves were needed. I have sent them emails requesting info on other things and they have never replied to me. I wouldn't bother asking them in this case. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | i am going with drum-drum so i am going with cpp bracket and 10 lbs. pressure valve and a mc from my local advanced auto parts store hope that will work? thanks guys with all the info | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Keithfielder, you should be able to get your F.L.A.P.S. to come up with a master cylinder for a drum/drum application, if they can then no additional residual valves should be required, hope that helps. | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | have you checked for a 70 Malibu master cylinder, that should be drum/drum, and already have residual valves built into bottom of master and be very reasonably priced, I'd guess? | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | my auto parts store is getting me a master for drum brakes so i do not need pressure valves from cpp? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You have to decide whether you want to use the valves. Personally I would not go without them. You must also find out if they are built into the new master cylinder. | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | i am useing a mc from a 1970s and i do not need valves and i just order bracket from cpp i just have to get all new brake lines and hoses thanks guys for all the info. | | |
