| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | I am finishing up on "getting the bugs out of my project". I took my truck for a ride a week ago after installing a new vacuum advance. It ran very strong but I have noticed that the triple core radiator I installed is designed for an 8 cylinder engine and the 235 runs exceptionally cool, like 160 degrees on the temp gauge. This past weekend the air temperatures were cooler and the engine temperature stayed cooler around 150. The engine power was significantly less and I started thinking the operating temps for my engine are my only concern causing my changes in performance with this engine (yes it has a thermostat installed designed to open at 180 and the engine is getting that hot and opening the thermostat)Would the engine temperature be causing significant performance changes? | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Sounds like a bad stat. Before you install a new 180, do a stove top test to make sure it opens at 180ish.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
