2 members (Bucker, latroca52),
111
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10927 05/13/2002 3:08 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Hey guys, I finally got my carb troubles almost licked. Just one more problem. It runs absolutely beautiful on the flat. But when I get to a hill and stop, and try to start moving again, it just sputters and dies. Then, when I start the engine back up, it doesn't wanna idle very well and I have to put the E-Brake on so I dont roll back and sorta feather the gas. Anyone have an idea? Thanks.
Chad
1955 Chevrolet 210 2 door Sedan a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
#10928 05/13/2002 4:22 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Yup, the answer is- "time it"!!
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#10929 05/13/2002 4:23 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | You might have something floating around in the gas tank that is covering up the fuel outlet occasionally.
How good is your fuel pump?
Is your tank vent open and functional? | | |
#10930 05/13/2002 5:20 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Dwell/timing has been set. Its got a brand new gas tank/sending unit/filter/fuel pump so I'm not sure if theres anything floating around in there. Could it be somethin in the carb? I just set the float but could it be anything else? It runs so well on the flat ground. And if i'm drivin up a hill, its absolutely perfect. Its only when I stop moving and start again.
#10931 05/13/2002 5:36 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | My wife just had the same problem with her 63 Dodge Dart and I checked the timing and for some reason the hold down on the dis. was loose. Set the timing and problem went away. Oh- It also ran fine out on the road. Do yourself the favor and check the timing again and hopefully it will fix your problem.
#10932 05/13/2002 5:50 AM | | Anonymous Unregistered | | Anonymous Unregistered | Sounds like your vacuum advance is bad. | | |
#10933 05/13/2002 5:59 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | My 235 did the same thing. It was a cracked head.
delete my account and pictures
#10934 05/13/2002 4:58 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | .Could also be a vacuum leak at base of carb,vacuum advance leaking internally,or leak at manifold to head.
#10935 05/13/2002 11:44 PM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | I just put a brand new vacuum advance on, new gaskets on the carb, and new intake/head gasket. Still does the same thing. Haven't checked the timing again yet....Thanks for the info so far guys! Keep it comin!
#10936 05/14/2002 1:22 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | .Did you have the manifold checked foe a straight surface?It CAN still leak with a new gasket. .How does it run when it is cold? does it do the same thing? .I would check and set the point dwell and the timing,then put a vacuum guage on it while running and warmed up.should be around 17 to 20 in.Hg on the guage. .Make sure you set the dwell first and the timing second.
#10937 05/14/2002 5:46 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | I'm gettin around 18 1/2 on the vacuum gauge. I did not get the manifold checked, however this is my second set of gaskets. I put my first set on and didn't scrape all the old exhaust gaskets off so it leaked. I looked at the intake gaskets when I took them off and there was an impression all the way around the port on each gasket, telling me the intake was sealed nice and tight. I will set the dwell and check the timing once more to make sure its right on. Thanks a lot guys....keep the ideas comin! I really appreciate it!!!
#10938 05/14/2002 6:11 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Sometimes it's the simple things that bite us in the rear axle. I see timing has been mentioned several times, have you thought about a bad coil? Most times a bad coil will not be able to produce enough voltage under load to keep the engine running.
Try this. Get engine warm, drive truck in high gear at a slow speed. (lug it) then romp the throttle. A coil that is marginal will usually crap out then. This test doesnt work in neutral, engine must have a load on it.
Good luck | | |
#10939 05/14/2002 3:21 PM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | My '48 would miss at higher speeds (if you can call 40 MPH "higher speed"). Twisting the distributor grease cup solved the problem. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#10940 05/14/2002 11:03 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Just out of curiousity, is the distributor "tight" in it's mount? Is there any slop in the distributor when you twist and shake it?
I recently learned that the fly weights on the bottom of the distributor can become dislodged and screw up a properly timed engine.
The fact that it's hick-upping under load points improper advance (vacuum as MT pointed out) but it could be under the plate with the fly weights??
I dunno. Justa thought | | |
#10941 05/15/2002 4:44 AM | Joined: Oct 2001 Posts: 45 Member | | Member Joined: Oct 2001 Posts: 45 | Hey guys, timing/dwell is spot on. brand new coil. brand new condensor, there is no slop in the distributor. I'm runnin out of ideas!!!!! Oh, today I took it out and drove it hard. I noticed that when i hit the gas hard when I drive, it misses a little, and then takes off. I'm almost thinking maybe carburetor problems? But I just rebuilt it and the float is set right. Well, if ya got anymore ideas keep 'em coming! thanks.
chad
#10942 05/15/2002 5:16 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | This has been mentioned before and it bears repeating: When rebuilding the carb. did you notice there is a small port in the base of the throttle body? Were you careful to align the new gasket so this passage is not blocked? This is the vacuum port for the power valve, which accounts for maybe 10-15% of your total mixture volume. If the engine is tuned to run well when this port is blocked, there won't be sufficient fuel enrichment on hard acceleration. If the port is open and has a vacuum signal, the valve will be closed (cruising position). If you open the throttle quickly, there will be no vacuum (or almost) and the power piston will pop-up, adding the necessary fuel mixture required. I've rebuilt so many carbs, I hope I am remembering this correctly!!  :o
*** GMC ***
#10943 05/15/2002 4:49 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Check that the accel pump is work in the carb. You can look down the carb and pump the linkage. You should see gas shooting out into the bore.
if it dosen't need fixed, break it
